best heads for trex cam
Old 05-28-2009, 02:06 PM
9secbird's Avatar
Default best heads for trex cam
looking for a set of heads for my cam only trex car, looking for the most power and cleareance i can get. let me know what you think
Old 05-28-2009, 03:33 PM
cellulis44's Avatar
tfs, afr
Old 05-28-2009, 09:40 PM
LS1-NAVY's Avatar
prc 215's they can fit with the ms4 i think without fly cutting but dont quote me on it
Old 05-28-2009, 10:08 PM
cellulis44's Avatar
yea.. out the box they can make you run a world record run too........................
Old 05-28-2009, 11:04 PM
Restricted User
willyfastz's Avatar
That's qoute able right there.
Old 05-29-2009, 12:46 AM
w3s1c0a5t's Avatar
^--- you 2 have a few friends? Then we would have a tool set.
Old 05-29-2009, 11:38 AM
cellulis44's Avatar
OOOOHHHHHHHHHHHH SNAPPPPPP...
You have their heads? cuz then we would have a nutswinger
OOOOOOHHHHHHHH DAAAMMMNNN...
Old 05-29-2009, 11:42 AM
w3s1c0a5t's Avatar
Sure dont punkin...
Try again with a random premade post?
Old 05-29-2009, 11:48 AM
WSsick's Avatar
wow, this unnessicarily turned into a bullshit thread.
back on topic, id definately check into those prc heads, along with some AFRs also. theres a realllll nice set of Tony Mamo ported AFRs in the sponsor sales section, lemme go check if its there. no promises itll have PTV clearance with a t-rex though. (custom cam would work great with these)
edit: ok those are gone. so back to the normal AFRs & PRCs. great choices none the less
Old 05-29-2009, 12:02 PM
cellulis44's Avatar
gone but watching....
we are all entitled to an opinion.
and could really care less.. I dont deal with tsp anymore for some expensive reasons.
maybe I have a little animosity.. but I have it after a $5000 reason
Old 05-29-2009, 03:46 PM
PREDATOR-Z's Avatar
243 Cartek 4X stock valved
Old 05-29-2009, 08:07 PM
Firehawk441's Avatar
Very good suggestion.
Old 05-29-2009, 09:16 PM
KCFormula's Avatar
Anything with stock valve size and no milling.
From there all you got to deal with is the runners and bowls. Anybody can do that.
Old 05-29-2009, 09:38 PM
w3s1c0a5t's Avatar
Stock size valves? what about a vj?
Seriously considering this cam...
I would figure this cam would kill for some milling...
Old 05-29-2009, 09:44 PM
Sharpe's Avatar
The TRex was designed for max cam only applications. If you want a big cam AND heads, then get another cam.
Old 05-30-2009, 04:23 AM
PREDATOR-Z's Avatar
It will work great with the heads I mentionned, better than with stock heads. That cam likes to breath and ported heads will allow that.
Old 05-30-2009, 08:42 AM
johnster's Avatar
this kills me!!!!
go to the dyno section patrick g dyno;d a trex and afr heads and it but down rite at 500, in a 346 with fkycut piston.
Old 05-30-2009, 01:24 PM
NemeSS's Avatar
any cam with upgraded heads will make more hp, even the stock cam
however the Trex was designed for a stock as is head. also works very will with good ole stock 243 or 799.
Old 05-30-2009, 03:26 PM
PREDATOR-Z's Avatar
It was designed as the biggest cam they could fit in a stock motor at the time.
Bigger is hardly always better, it needs a boatload of modifications to support it, it is not a street cam. It was designed as a cam only drag cam. And unless you drive around with slicks, 4400+ stall in a 2750lbs car you would be making a huge mistake shoving that cam in there.
Old 05-30-2009, 04:04 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We are currently finishing up a larger runner PRC cylinder head that was designed for 3.910 bore applications. That being said they don't currently clear p/v with a Trex. The last Trex I checked was a good bit worse clearance than the MS4 & the MS4 won't clear with this new PRC 346 cylinder head. The PRC 215 head should work good for you, or if your on a budget the PRC LS6 Stage 1 can keep stock clearance & give you a 63cc chamber.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Quick Reply: best heads for trex cam
