TR236 installed
Old 11-09-2003, 10:01 PM
Moderator
LIL SS's Avatar
Default TR236 installed
Got the car up and running today. Idle is at 800 RPM. Another TR236 user made some changes to my edit file so it runs awesome. Here is a sound clip.
TR236
This is on stock heads. I have the cut out closed for the first 5 or so seconds. Car is warm as well.
I'll give more impressions of the cam as I get to drive it more.
Old 11-09-2003, 10:16 PM
John02SS's Avatar
Damn that thing thumps! Congrats!
Old 11-09-2003, 10:26 PM
LS1Tech Sponsor
Slowhawk's Avatar
Congrats on getting it running.
Glad the file I did worked good.
Classic's Avatar
Sweet!! Makes me miss my cam a lot - need to get my new setup done ASAP. This will probably be the cam I'll be running as well.
Congrats and have fun.
Old 11-09-2003, 10:27 PM
Mike K.'s Avatar
Wow that sounds nice. Especially with the cutout open. I'm sure that will turn heads at nearly every stop light.
Old 11-09-2003, 10:28 PM
Moderator
LIL SS's Avatar
Don I can't thank you enough for the help on that. It was nice to upload it and have it going.. BTW, I dropped the idle down to 800 Your an A4 correct. I have no problem at 800rpm with the M6.. I was even thinking about trying to drop it to 750-775 to get it to really sound mean
Old 11-10-2003, 01:06 AM
jrp
SN95 Director
jrp's Avatar
wow, that sounds awesome, what are the specs? sounds really quite with the cut out slosed though, my car sounds like yours does with the cutout open just at regular idle and i dont have a cutout. i still havent tuned mine yet though so i dont know if the sound will change, its at an 800rpm idle.
Old 11-10-2003, 05:51 AM
LS1Tech Sponsor
Slowhawk's Avatar
Sorry I don't like lope so I set my idle higher.Take out that tune and you'll feel serious lope(if it even will idle)
The fun part of that Cam is how far it revs.I've tested it to 7200rpm and it was still going and it even lugs around at 1200rpm.
Old 11-10-2003, 09:37 AM
Moderator
LIL SS's Avatar
7200 RPM.. Man that's high.. Where did it peak? I don't think I'll be spinning the stock bottom end to 7200.. I might go to 7k on the dyno.
Old 11-10-2003, 10:29 AM
DanZ28's Avatar
Shaun, sounds awesome bro!! Glad it's all up and running and there is no problems (not like there would be ). I may just have to pick that TR236 up off the garage floor and put it in now, lol!!
Anyone have a dyno graph with this cam??
Dan
Old 11-10-2003, 10:42 AM
ScreaminSS01's Avatar
What is the lobe seperation? If it was on a 112 I want to know how you got it to idle that low!
Old 11-10-2003, 10:58 AM
DanZ28's Avatar
It is on a 112 LSA. According to the cam doctor sheet Shaun has, it's on a 109 ICL, so that would be 3 degrees ground in right? As far as being able to idle that low, I see no reason a M6 should not be able to do it with the right tuning, but maybe the guy that tweaked his LS1 edit file can explain what he did, if anything special...
Dan
Old 11-10-2003, 11:41 AM
Is there anyway I can see your tuning file? I am not sure the process.Do you have stock injectors?
Old 11-10-2003, 12:36 PM
Moderator
LIL SS's Avatar
Dan, Here is the link from Slowhawks pull. I think the dyno overlay is the TR224 and the TR236.. https://ls1tech.com/forums/dynamometer-results-comparisons/98686-tr-236-230-results.html
Injectors are stock (28.8lb).. I feel Slowhawk would have to give the ok on the file just because he was the one that did it. I don't want to just give away his work. Hope that makes sense..
Old 11-10-2003, 12:47 PM
DEEZ98Z's Avatar
looks like the lil 224 holds it own up until 5200 What are the specs on that beast? It sounds nice
Old 11-10-2003, 12:50 PM
black_z's Avatar
Sounds really mean.
Old 11-10-2003, 12:55 PM
Moderator
LIL SS's Avatar
236/230 .599/.573 112lsa
Old 11-10-2003, 01:01 PM
DEEZ98Z's Avatar
Thanks LIL SS
Old 11-10-2003, 03:05 PM
I understand what you are saying and its ok. I will PM him.
Old 11-10-2003, 03:58 PM
LS1Tech Sponsor
Slowhawk's Avatar
The dyno does peek the same as a 224..The dyno I run on in very well known as a very low reading dyno,but I do all my pulls there since I work there
My car stock was 300hp,I've hit 440rwhp on the dyno but the car ET's better with the lower hp #'s.(3mph difference)Meaning dyno #'s mean little
