good set of heads
good set of heads
I'm wanting to run the torquer v3 in my 00 ls camaro and was wandering if the prc stg 2.5 ls6 heads would be a good set of heads to run with that cam? The car is a m6 with lid ram air ported tb slp lts and tds any help is appreciated
LS1Tech Premium Sponsor
For the money the PRC LS6 Stage 2.5 heads are really hard to beat. If your wanting aftermarket castings the PRC 215s are a great option. We're also working on a new larger runner 3.900 bore LS head that flows some really big air & clears with the Torquer 3.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I will be doing engine dyno testing of these heads compared to a few competitors heads. If you'd like to come down for the testing let me know.
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Ok fellas I've decided to go with the torquer 2 cam I'm hoping the jason from tsp will chime in. What size pushrods. Do I need to order with this cam and heads and also what type of lifter will work best? with the
