HELP swapped engine,NO OIL PRESSURE
Old 07-07-2009, 09:45 PM
wicked-98's Avatar
Default HELP swapped engine,NO OIL PRESSURE
I just finished my engine swap today on my 98 Z28.It fired up fine but there is no oil pressure at all.I tried it 3 times in 10 second intervals and still nothing how do I know if the sending unit is bad or my oil pump or wires or gauge?please help
Old 07-07-2009, 09:49 PM
conan's Avatar
Pull off the oil fill cap and see if there is oil on the rockers. You could also pull the rocker covers and check for oil up top. If you have oil go after the sending unit. If not check the oil pump O ring and pump.
Old 07-08-2009, 08:52 PM
wicked-98's Avatar
I pulled the oil filter and its dry as a bone so I now know its either the pump or the o-ring.Is there a way to put on the head gaskets wrong as to cover the oil flow?
Old 07-08-2009, 09:42 PM
conan's Avatar
If the filter is dry you have pumping problems. What all was done to the engine during the swap?
Old 07-08-2009, 10:16 PM
JRracing's Avatar
Is the battery fully charged? Is the motor spinning pretty fast? Also, how long did the motor sit since it was last running?
I had to pack my pump with a little bit of lube to get suction so it would pull the oil out of the pan. And crank the motor fast until we seen oil up top.
Old 07-08-2009, 10:23 PM
blk00ss's Avatar
You can pull all of the plugs, and spin it over. You should see pressure in a few seconds. Dont forget to pull your fuel pump fuse so as to not wash your rings...
Old 07-08-2009, 10:37 PM
JRracing's Avatar
Very good idea. I had to do this also.
Old 07-10-2009, 12:16 AM
wicked-98's Avatar
I had to pack my pump with a little bit of lube to get suction so it would pull the oil out of the pan. And crank the motor fast until we seen oil up top.[/QUOTE]
This makes sense to me I think I'm gonna try this next cus it has been sitting for about a year.I sprayed the whole thing down with oil and lubed what I could.I'm afraid to turn it on now or even turn it over
