ls3/ls9 cam in pre 05 block?
Old 07-09-2009, 09:31 AM
00Wildcat's Avatar
Default ls3/ls9 cam in pre 05 block?
do the later model factory cam blanks have the hall effect trigger ground into them, so they can be used in earilier engines? for example can i use an '08-'09 LS9 cam in an '03 LQ4 truck engine?
Old 07-09-2009, 08:05 PM
5_02ls1's Avatar
No.........
Old 07-09-2009, 08:15 PM
00Wildcat's Avatar
thanks.
Old 12-16-2009, 11:24 AM
pdasterly's Avatar
I have a LS9 cam in my 98 LS1, I extended the cam sensor wire and bought a LS2 timing set with the front cover.
Old 01-23-2010, 10:39 PM
blacksi's Avatar
Did you have to change the rockers? 1.7 vs 1,8
Old 01-24-2010, 11:06 AM
cutlass_455's Avatar
What sort of change did it make over your old cam??
Old 01-24-2010, 11:07 PM
pdasterly's Avatar
using stock ls1 rockers
Old 01-24-2010, 11:08 PM
pdasterly's Avatar
can't really tell you because the motor has been rebuilt with forged parts and the cr is 9.1. also did heads and a procharger.
Old 06-06-2010, 02:34 AM
nasty_ss's Avatar
where did you get the timing set and cover?
