What do you think broke
On 9-6-03 I ran a couple of bike's (and beat them )but my engine started sputtering and making really wierd noises (blown engine noises)when I got of the freeway.I decided to punchit to see what would happen and it lugged and surged hard until about 2500rpms and then it accelerated normally but still making noises.So I've done a compression check and the right side all had 145-150psi while the left side had 170-175psi I removed the valve covers and didn't find anything wrong so I will pull the intake manifold in a few days to check the pushrods and lifters I had an ses light on but it was already on since I blew the left side cat a few weeks before hand .I probobly won't be using a scanner.Sorry for the long post,hope you guys can help
when you put the rocker arms back on do you have to adjust them in a specific order or do they just get torqued to a specific amount via torque wrench?
sound's like you may have lifted a ring land. I did it once and the engine sounded real bad. The piston parts that came undone had closed the gap on a sparkplug. So I knew what cylinder was hurt. I changed the plug and the car ran fine.
Compression check was normal also. Then I did a leakdown test.And found my problem.
SN95 Director
Originally Posted by jrp
tq the bolts down 20ft-lbs the first pass, then turn the engine 180* and retorque to 22ft-lbs.
SN95 Director
cool thanx also,how do you do a leakdown test?
http://www.ls1.com/ldtest.htm
http://www.ls1.com/cylinderleakagetest.htm
I haven't gotten around to do a leakdown test but since the whole right side(passenger) head had lower compression readings than the left.Do you think it's a busted head gasket?
