ANOTHER cam spec thread
Old 08-02-2009, 02:51 AM
jetlag's Avatar
Default ANOTHER cam spec thread
Yes, I know..a ton of them out there. I've been searching, lots of great opinions/advice.
Now, let's try to find one for my car.
Pacesetter LTs
Flowmaster merge collector
Powerbond 25% underdrive pulley
lid
Yank SS3600
3.50 gears
I recently bought 799 heads (same as LS2 243s) that will be getting installed. They will be left unmodified. And I plan on using the single PAC springs.
I do have a nitrous kit, but I'd like a cam geared more towards N/A because I rarely use the nitrous and it's only at the track. So the car needs to be fun on the weekends. (100-125 shot max)
Old 08-02-2009, 03:32 AM
PREDATOR-Z's Avatar
227/231 .614/.617 110+2 LSA
Pac 1518 single beehive
Old 08-02-2009, 02:30 PM
JPH
JPH's Avatar
Damn close to what I was going to recommend Mark. LOL
228/232 .600/.600 112+5 is what I have liked and used with similar combos. (give it 11.25scr and an intake and go have fun)
Old 08-02-2009, 05:00 PM
jetlag's Avatar
Will that have a nice thump to it? When ordering a custom cam like that, what do I need to specify? Lobe type, etc?
Old 08-02-2009, 05:20 PM
Nitroused383's Avatar
Ya it will thump pretty good with 9 degrees of overlap. Predator-Z specced LSL lobes and I do not think it is recommended to run the single beehive springs with those lobes. A little to agressive for that. You will need to run xfi lobes to run those springs. That cam should sound similar to my 224.
http://www.youtube.com/watch?v=Ed8s0ovoQDU
Old 08-02-2009, 06:29 PM
quick346's Avatar
it kills me how so many are willing to fork out $400 for a custom cam but can't spend $25 for pat g to spec them a cam that works with the gearing and scr and figure the dcr for you.
and tell you what push rods and springs to run.
too bad you cant buy commen sense. it would be worth every penny to most. LOL
or you could down load a dcr calculater and do some calculations of youre own if you cant do the $25 for one to be specced but most would rather ask a stranger what will make them happy. with out fly cutting of course
Old 08-02-2009, 06:47 PM
jetlag's Avatar
Ignorance is bliss?
Sorry, I didn't realize Pat G charged a fee....and I've seen some pretty good results from Predator-Z's recommendations.
Maybe he should start charging.
Old 08-03-2009, 02:06 AM
Spend $50 and have your heads milled .020", this will put them right at 62cc's. With the $28 GM MLS gaskets you will be right at 11:1 compression. Otherwise stock LS6 heads are around 64.5cc's and 10.5:1 compression. The GM MLS gaskets are .051" thick and if your pistons stick out .006-.008" you will have a great quench around .045". I run 9.0:1 DCR and 11:1 static compression with no issues on 92 octane fuel, very torquey setup and has no loss of power anywhere. Also as the bare minimum atleast lap your valves in, GM's valve job is a joke and is far from concentric.
Old 08-03-2009, 08:50 AM
stumprrp's Avatar
I really like how my cam performs and how it drives.. I can be in overdrive at 38 mph and it won't buck just drives smooth.. 230/236 612/607 on a 114.. The curve is flat and top end pull is insane.
Old 08-03-2009, 06:26 PM
hammertime's Avatar
Single behive springs are advertised to handle that amount of lift, and have much less mass moving than dual springs and the larger retainers. Properly setup, it should work ok. Duals might make you more comfortable, but consider the physics in the situation.
That said, making the cam work does take some patience and requires the setup to be spot on. XE-R lobes will come close to the same amount of power with a little greater margin for error. The difference is usually in the details.
Old 08-04-2009, 03:44 AM
PREDATOR-Z's Avatar
Pac 1518 will handle those lobes but not the 918s, there is a difference between the 2.
Comp cam came up with dual 926 springs around the same time they released the LSL (LSR) lobes and holy behold, suddenly only the 926 will handle the lobes
.600>.050 variance on LSL is 50 and XE-R 49 so off the seat XE-R is actualy sharper.
Old 08-04-2009, 04:59 AM
I didn't realize that, when I talked to Patrick G about it he said I would need the PRC extremes and no to the beehives. He spoke to the guy who designed the lobes so I'm just going by what I was told.
Old 08-04-2009, 06:22 AM
PREDATOR-Z's Avatar
It also depends on the valve you are using and rpm at which you are spinning.
The Pac 1518 are within the pressure parameters of the LSL lobes.
In general as you well know, poeple tend to use duals for more "peace of mind".
If those lobes were so harsh, springs would be just part of the worries and those lobes then should only be run with Morrel or Comp "R" lifters, but they are working fine with LS7s and such.
I have some on 850-16 comps with no issues to date.
If valvetrain is well centered (proper geometry) and right preload on lifters, the LSL are easier on the valvetrain than LSKs.
Pac 1518
Premium Nitrided Beehive LS1 Spring
OD: 1.290"
130 lbs @ 1.800"
337 lbs @ 1.150"
Lift: 0.650"
Old 08-04-2009, 05:27 PM
JPH
JPH's Avatar
Duration numbers @.050 usually will determine what "lobe family" you will be getting.
