What can i expect with a 212/218 and 3200 stall?
Old 08-29-2009, 11:35 PM
juanjuan07's Avatar
Default What can i expect with a 212/218 and 3200 stall?
I have a 2001 WS6 A4. The car have: SLP Cold Air Intake, LT hearders, no cats, ported TB, 212/218 114 cam, LS6 intake, LS1 heads ported( not to much), tuned, lower control arms, pan hard, SFC, and now i am puttung an FLT Level 4 with 3200 stall. What can i expect of it in the 1/4 mile? altitude 0, temp 90+, street tires
The car made like 360rwhp, but that was without the stall
And do i need to tune it for the new stall??
Old 08-30-2009, 03:49 AM
PREDATOR-Z's Avatar
expect about 20>25rwhp with that cam. Tuning for a TC is beneficial, reduce trq management, shift points etc...
Old 08-30-2009, 07:56 AM
stumprrp's Avatar
should be a very torquey setup and fun to drive. in the high 11's for sure.
Old 08-30-2009, 07:58 AM
adkunlimited's Avatar
you wont really gain any hp with the converter. it will just make the car launch at a higher rpm. kinda like dumping the clutch at 3200 rpm on a m6. also like PREDATOR-Z said you will need to tune for it to get the most out of it.
Old 08-30-2009, 08:29 AM
DaveX's Avatar
How do you figure high 11's? Just curious. You have a bigger cam, higher stall, and weight reduction and are at 11.90.
I would say mid 12's if it's a full weight car.
Old 08-30-2009, 09:03 AM
juanjuan07's Avatar
YEp, it is a full weight car. Will a be able to be between 12.1-12.5's?
Old 08-30-2009, 10:12 AM
PREDATOR-Z's Avatar
Yes you could if car is setup properly.
But you'll need skinnies, and proportioning valve and LCAs with relo bracket.
Old 08-30-2009, 09:26 PM
stumprrp's Avatar
i also have less power, 0 suspension mods, and bald tires. im assuming he has these.
Quick Reply: What can i expect with a 212/218 and 3200 stall?
