Looking For Reliable Sleeper H/C Set-up
Old 09-01-2009, 12:07 PM
Z06FRC's Avatar
Default Looking For Reliable Sleeper H/C Set-up
I'm looking for any suggestions for a reliable sleeper head/cam set-up. It's for my 99 Vette that I daily drive in the summer. It's mainly a street car that I take to the track once in awhile. I would like something that runs like stock, with very good power gains, reliable and emission friendly.
Old 09-01-2009, 02:30 PM
PREDATOR-Z's Avatar
224/228 .604/.588 114+4 LSA
Custom
Old 09-01-2009, 02:32 PM
matt1289's Avatar
If you have the money AFR's are emissions friendly, A cam about the size of mine or smaller might be what you are looking for.
my car runs like stock with a little lobe to it, not as much lobe as I would like though.
Bad Blue WS6's Avatar
pardon my stupidness, when you have a in/out of over .600, (like that one ^ that shows .604) do the pistons need to be notched for the clearance issue?
Old 09-01-2009, 02:36 PM
PREDATOR-Z's Avatar
No, max lift at .050 has nothing to do with PTV clearances.
Old 09-01-2009, 02:40 PM
that has to do with the springs and how much they can handle,,, right?
once again, sorry for the really dumb questions, im just getting into the cam research stuff,,,, and theres sooooooooooooo much, its confusing me a bit.
Old 09-01-2009, 02:45 PM
PREDATOR-Z's Avatar
Clearances have to do with duration and LSA/ICL near TDC.
You can run Pac 1518 singles with the cam I gave.
Old 09-01-2009, 03:13 PM
TransAmcoupe98's Avatar
Check out Thunder Racing's CheaTR cam and AFR heads package. The AFR 205's are emissions legal and the CheaTR cam would be exactly what you are looking for and make some really good under the curve power. AFR's are sorta pricey but you get what you pay for. Especially to stay emissions legal...Check out the link below. Thunder made 394 WHP with this setup using stock manifolds, catalytic converters, and exhaust.
http://thunderracing.com/catalog/?ac...vid=7&pcid=289
Old 09-01-2009, 03:24 PM
SS4Luck's Avatar
+2, i was goign to reccomend the CheaTR setup, most guys see 400+ to the tire with GREAT characteristics
Old 09-01-2009, 03:25 PM
eamador11's Avatar
^^^I agree and you can leave the stock exhaust manifolds on.
Old 09-01-2009, 03:39 PM
Z06FRC's Avatar
My car is a 6-speed manual with the fallowing mods:
-LG Street Headers with high flow cats
-80mm throttle body
-Magnaflow cat-back
-LS6 intake manifold
-Vararam Intake
-Ram Powergrip HD Clutch
-Yella Bullet Steel Flywheel.
My goal is to make 400rwhp or more.
Old 09-01-2009, 03:52 PM
-80mm throttle body
-Magnaflow cat-back
-Vararam Intake
Whew, well with those bolt-ons you have, you will EASILY put down 400whp. I will say 425whp with the AFR's and CheaTR cam...I think you will like that alot.
Old 09-01-2009, 04:03 PM
Z06FRC's Avatar
For the heads, should I go with 66cc, 64cc or 62cc combustion chambers? The car usually runs on Shell 91 octane and I like to keep it that way.
Old 09-01-2009, 04:05 PM
02SLOMARO's Avatar
i really like my 224/224 cam and prc stge 2.5 cnc'd heads. i also have lt's, ud pulley, slp mass air/cai, and no cats. i am probably pushin 420-430ish, and i drive it everyday. if i only had h/c, i would say i would be around 380-390ish. i only run 91 octane.
Old 09-01-2009, 05:35 PM
DSkyles's Avatar
A friend of mine put down 403/403 on ls6 heads and ls6 cam. I'd just pick up some 243's and a mid-size cam. You can get 243's for 600 and less
Old 09-01-2009, 10:54 PM
TurboTSI_1991's Avatar
vettes are beautiful cars but not really a "sleeper" car. i say park the vette and get a camaro.
Old 09-01-2009, 11:34 PM
NVR_SPDS's Avatar
AFR 205s, and their 6016 cam seem to makes great power, with little to no lope at all. Its only a 224/228, so its not really a big cam. I believe its the cam in my friends firehawk, which made 448rwhp with LS6 intake.
Old 09-01-2009, 11:56 PM
transamfreak01's Avatar
ill add another vote for the thunder racing package. if you want it as stock as possible then i would get that set up. its only going to be a sleeper though until someone looks under the hood. then the secret is out
Old 09-02-2009, 05:19 AM
64cc. With a stock MLS head gasket, that should put you around 10.5:1 CR.
Old 09-02-2009, 11:11 AM
30th t/a's Avatar
nevermind
