Camshaft scratch. Any idea what caused and if I need to replace it?
Old 09-19-2009, 01:39 PM
LastBlack02SS's Avatar
Default Camshaft scratch. Any idea what caused and if I need to replace it?
Here are some pictures of the camshaft in my motor. I noticed these yesterday as I was getting everything ready to assemble. Naturally I turned it over with a wrench to inspect stuff prior to getting the top end on. Noticed these relatively deep (fingernail deep) scratches on the camshaft. What could cause this? Do I need to replace it?
Attached Thumbnails Camshaft scratch. Any idea what caused and if I need to replace it?-cam-1.jpg   Camshaft scratch. Any idea what caused and if I need to replace it?-cam-2.jpg   Camshaft scratch. Any idea what caused and if I need to replace it?-cam-3.jpg   Camshaft scratch. Any idea what caused and if I need to replace it?-cam-4.jpg
Old 09-19-2009, 02:36 PM
01ssreda4's Avatar
Damn those are some big gouges.....
Old 09-19-2009, 02:38 PM
george g's Avatar
cam is trashed. check the lifter
Old 09-19-2009, 03:01 PM
Formerly darynC-10/23/10
Daryn's Avatar
take your cam out and look at it. if u can feel deeg gouges then its prolly not salvageable. its its just a scratch. u can prolly polish it out or send it to the place who made it and they can take some off of it, then u will have to cam doctor it again to see the new specs of it
Old 09-19-2009, 03:34 PM
Damn. Yea, they're deep. Fingernail deep. I'm guessing new cam is needed. Now the bs of figuring out what cam to use.
Old 09-19-2009, 03:50 PM
Daryn's Avatar
new lifters indeed also!
Old 09-19-2009, 11:08 PM
Monte4ever's Avatar
Looks like the bearings in the lifter wheels came out and let the body of the lifter contact the cam. I had two lifter wheel bearings go out on me in a BBChevy and it wiped out a couple cylinder walls, the cam, and a few pistons. With gouges like that you need to check everything.
Old 09-22-2009, 02:56 PM
I checked everything. Everything else looks fine. Lifters actually look ok too, although it is pretty unnerving to reuse them. I bought this motor here on the forums and hope that they will replace this cam as it clearly needs to be replaced.
Old 09-22-2009, 07:22 PM
DaddySS's Avatar
Looks to me like a lifter failed and was replaced.
Quick Reply: Camshaft scratch. Any idea what caused and if I need to replace it?
