TR 224/224/114 Warranty Problems?
I am thinking of getting this cam due to its ability to pass emissions here in CA. My question is, if I go in for warranty work, will they be able to tell I have swapped the cam? I have stock exhaust with a cutout and electric plate, so if they see that, they will know I have done some work on the exhaust, but through the stock exhaust, will you be able to hear this cam? Thanks for any help!
Most dealerships wont even care. They will just think you have exhaust work. If you needed both banks of lifters replaced under warranty, and they had to really open the engine, then that might detract them from doing warranty work. The dealership I work at could give two ***** about a cam. As long as the porters can easily drive it, it is good to go.
Hey bro let me kno what kinda numbers u get with that cam, cuz i have basically the same set up have in an 02 SS and i wanna get that cam too, but i heard its iffy on passin emissions, but anyhow let me kno ur dyno #'s when u get it
i initially failed NY inspection with a mild cam 220/220, 564/564, 112...my heads were milled .055, however...
...after an LS1Edit tune and 12 bottles of methonal (dry gas) to a 1/4 tank of gas, it finally sqeeked through...
...find out what your state limit is for hydrocarbons...if it is say 60PPM, you probably won't pass with the 224 cam...
Originally Posted by skytower31
My question is, if I go in for warranty work, will they be able to tell I have swapped the cam? Thanks for any help!
Alright killer, now you're starting to scare me!
j/k, anyway, I do tend to care about learning about law once I started doing potentially "illegal" things with/to my car
Also, do you think I would again, officially be a non-noob once I install my own cam? Huh, huh, what do ya think now, huh???
But really, I am not sure when I am going to do the cam, but it is a must. Warranty is really my only reason for not doing it yet! Plus she is still the daily driver so I can't mess her up and not be able to drive her to work!
This is good to know as i live in Elmhusrt and thinking about cammin up my 03 z06. What dealership are you referring to and if you prefer, feel free to send a PM.
THANKS!
I had some dealer work done to my SS and they did not care about the cam....they even went so far as to try and slip it by the adjuster.....but on my second claim the adjuster saw the long tube headers and they voided my warranty....so much for that...only if they knew what else was in the car besides those headers
I am installing a 230/224 myself as well.
You should be very good shape with a 224/224 though
and you have long passed noob status, I was just at ya with your low post count..... but then mine is not in the 2k area here either huh
THANKS!
THANKS!
Try Larry Roesch Chevrolet on Grand avenue. When ever I brought in my Camaro all the guys ever wanted to talk about was what I had done and about my stereo. It would take me and hour to get an oil change 30 minutes for the change and another 30 just shooting the **** with the shop guys.
Interesting...do you have any more info on that law?
