using tons of oil what would you guys do?
Old 10-13-2009, 09:50 PM
chadnol10's Avatar
Default using tons of oil what would you guys do?
Ok i know enough here to be dangerous but i'm looking for suggestions as to what to do. My 2000 Trana Am M6 w/60k miles uses a ton of oil. I"m assuming its bad rings. I use so much it fouls my spark plugs up right away. My exhaust tips have oil all over the place. I just put 243 heads and a custom grind cam 232/236 cam in last winter. I do'nt need anything hard core in this thing but is it worth while to bore it out w/new bearings and all or just have new rings put in? shoudl i get new pistons and stuff as well or what do you suggest with 60k miles??? I go to the track about 3 times a year and it does get driven hard on the street. It dynoed at 395 hp but the tuner at rapid thought with that cam and all my mods it should have been better numbers. looking for suggestions Thanks
Old 10-13-2009, 09:54 PM
LS6427's Avatar
Bad rings at 60,000....thats odd.
I'd say your valve seals are bad. I know the heads are 1 year old, but the valve seals can still be bad. Thats how raw oil gets on the spark plug tips. Not really by bad rings.
Other way alot of oil can go through the engine...stuck open PCV valve.
If you cruise steady at say 60mph....and then hammer the pedal to the floor.....do you make a cloud of bluish/white smoke? Thats bad valve seals.
Old 10-14-2009, 06:34 AM
chadnol10's Avatar
I just can't believe its valve seals. This problem was going on before my H/C swap and then I put new seals in and its still a problem. I also put on the LS6 valley cover before the H/C swap cause it was so bad. I did have a catch can but it didn't get to much i really thought it was the rings.
Old 10-14-2009, 06:39 AM
SOMbitch's Avatar
Do a leakdown test.......
Old 10-14-2009, 06:47 AM
99RTA's Avatar
pull oil cap off and rev the engine steady to 2500 and see how much blowby you see.
Old 10-14-2009, 07:06 AM
chadnol10's Avatar
how do I do a leakdown test?
Old 10-15-2009, 02:23 AM
ae13291's Avatar
its a kit you buy, what it does is pressureize each cylinder and you can diagnoise where the air is going out the cylinder, see how much blow by you have when the oil cap opens. i really dont think rings can be bad that early if the car was taken care of
Old 10-15-2009, 11:09 AM
SOMbitch's Avatar
http://www.carcraft.com/techarticles...ter/index.html
This is a pretty good article....... I have seen the testers on ebay for around $40
Old 10-15-2009, 11:26 AM
99blancoSS's Avatar
Did you pull the intake off and check the runners for oil ? Do the simpler things first. Oil on the TB blade?
Old 10-15-2009, 11:45 AM
futuref-body's Avatar
uh oh. what does oil on tb blade mean?
Old 10-15-2009, 11:49 AM
99blancoSS's Avatar
It means you are getting reversion. That tube that goes from the passenger side valve cover the to tb is the culprit. At hi rpm is sucks oil instead of flowing fresh air in.
They make dual catch can units for it, there is a thread here somewhere talking all about it.
Old 10-16-2009, 08:48 AM
chadnol10's Avatar
whoa whoa That is what my tuner said is that I had an oil reversion problem. I thought that just meant the oil is going past my rings. I had oil on my intake runners. what will a dual catch can do? I had a Revxtreme catch can but it was just 1 can. Will oil reversion cause a loss of power and is there a thread to fix this?????? Please HELP!!!
Old 10-16-2009, 09:10 AM
99blancoSS's Avatar
Reversion just means the flow is getting reversed in this case. But its good news for you! It can be fixed and you dont need rings or a leak down test.
I'll look for the thread and post it here. Yes suck enough oil in through the intake and it will effect power.
https://ls1tech.com/forums/generatio...outing-ok.html
If you have ported heads you also may need to seal the rocker bolts in the intake runners if they poke through.
Old 10-16-2009, 09:26 AM
chadnol10's Avatar
Perfect I want to do this. I saw on that thread that there is a dual catch can routing. between the valley cover the Throttle body also the manifold and the passenger side valve cover. Please recommend the best setup for me to go with. My passenger side valve cover is capped off that is what i was told to do will I need to uncap that and go with a dual setup I guess? Woudl i need vented or non vented systems. Let me know thanks for the help if this fixes this problem i don't care about money i just want the best setup.
Old 10-16-2009, 09:27 AM
chadnol10's Avatar
My setup is LS1 engine block with LS6 valley cover. 243 heads ported stock throttle body. I also have an LS6 intake.
Old 10-16-2009, 09:37 AM
99blancoSS's Avatar
Saikou Michi Dual is what is featured in that thread.
[/QUOTE]
You don't need to follow the turbo routing obviously but it will give you an idea. Long thread but there are some good illustrations in it.
Old 10-16-2009, 10:15 AM
chadnol10's Avatar
now are those good catch cans because i know some catch cans are worthless. It has to do with the inside of the can from what I understand. Also how comes I was told to cap the nipple on the valve covers before?
Where can I buy good cans. Thanks and sorry for all the questions.
Old 10-16-2009, 10:17 AM
chadnol10's Avatar
Last question - This fixes oil reversion or just helps with the problem?
Old 10-16-2009, 10:37 AM
99blancoSS's Avatar
It should fix the issue, RevXtreme makes a good can, I think those others are good but not sure. I know it says so in that thread.. it's long but go through it and you'll find all the info you need.
I don't carry them but I can and will set you up with all you need if you want me to. PM me and we'll take it from there
Old 10-16-2009, 11:26 AM
99RTA's Avatar
Unfortueatly its just masking the trouble. The intake side of the PCV system is supposed to flow back at WOT. Its designed that way to relive crankcase pressure. For sme reason you have too much.
