Up side down cam swap?
Old 11-03-2009, 11:24 PM
sawzall wielding director
G-Body's Avatar
Default Up side down cam swap?
So I pulled the entire engine to do the cam swap. I had to do an oil pan, front main, rear main, and rear cover gaskets so it was just easier. Now for the cam swap...since I have the engine out should I just flip it upside down when I go to pull the cam out?? I don`t have the JRP lifter tool and flipping the engine seems like a better alternative to dowel rods. Is there anything I`m missing?
Old 11-03-2009, 11:33 PM
therealthatguy's Avatar
only thing i can think that could possibly be a problem is oil getting into the top end/ intake.
Old 11-04-2009, 12:17 AM
ae13291's Avatar
since your engine is out i would do heads too while im there man, but i think it seems ok to flip it upside down. try it out
Old 11-04-2009, 01:02 AM
brianfromhawaii's Avatar
itd work bro!
Old 11-04-2009, 02:45 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I would be concerned about the lifters either coming partially out and not returning properly or potentially turning in the plastic retainers. I know the retainers are designed to prevent them from turning, but again they are plastic. I don't know how much space there is between the head surface and the lifters compared to their height, but I would avoid it. Go buy some wooden dowels for about $3 and do it the correct way.
Old 11-04-2009, 03:16 AM
camcamaro1991's Avatar
Thumbs up
With engine upside down, it will work.
i did it on my Crate engine and it took about 20 mins or so
since you have the oil pan off, i would recommend ARP rod bolts too.
Old 11-04-2009, 03:52 AM
davidws6's Avatar
Default Tool
I was thinking the same thing if I was going to due a future cam swap.
One member made me aware of putting 1/4 or 5/16 aluminum dowel rods through the holes behind the cam gear to hold up the lifters.
There's a write up on here about it.
Old 11-04-2009, 07:02 AM
highflyin's Avatar
Flipping the motor will work fine. There is no physical way the lifters can come out the top without taking the trays off.
Old 11-04-2009, 12:42 PM
youguessit's Avatar
true that
Old 11-04-2009, 11:53 PM
G-Body's Avatar
That is what I was thinking. I couldn`t imagine there being a problem doing it upside down. Maybe oil running to the top end, but I was going to already have the valvecovers, pan, and basically the rest of the covers off too so that wasn`t going to be an issue. I generally like to avoid getting wood near a motor, lint from rags is bad enough but wood debris in a motor could not be good. Now I just have to decide how I am going to align the front and rear covers and oil pan.
I think I`m going to end up putting the front and rear covers back on and then the pan.
Quick Reply: Up side down cam swap?
