LS1 vs. LQ4 windage tray
Old 11-11-2009, 02:02 PM
ss.slp.ls1's Avatar
Default LS1 vs. LQ4 windage tray
I know the LS1 windage tray is shorter due to the LS1 oil pan bing shallower.
I am going to be swapping a LQ4 into an Fbody, given that I already have a LS1 oil pan and pick up tube, could I simply cut the LQ4 windage tray with a grinder down to the proper LS1 length? I don't know if the LS1 pickup tube will still be able to bolt up properly or not...
Help is much appreciated, thanks.
Old 11-11-2009, 04:55 PM
blk96406's Avatar
Default windage tray
Im pulling my motor out tomorrow, I still have my "truck" tray laying here so I can compare 'em for ya...... but if I remember right, they are quite a bit different.
Old 11-11-2009, 06:14 PM
ss.slp.ls1's Avatar
Cool, post pics of the side by side comparison if you could.
Old 11-11-2009, 09:27 PM
OUTLWZ's Avatar
Whats wrong with the LS1 windage tray?
You could modify the LQ4 tray to work, if I remember right the difference is due to the LS1 oil pick-up tube.
Old 11-12-2009, 03:38 PM
ss.slp.ls1's Avatar
I never said there is anything wrong with the LS1 windage tray, I just don't have one. I need to fine one, along with a LS1 pick up tube that I thought I had... I have a pan, that's it.
Old 11-12-2009, 03:46 PM
blk96406's Avatar
Man, I got side-tracked today and havent touched the car yet. Ill try to get to it tomorrow for ya-
Old 12-19-2009, 08:35 PM
Josh18Fan's Avatar
The fbody windage tray is a bit shorter, due to the front of the pan being much shallower. If no pics are posted tomorrow, I can grab some when I get my tray out.
Old 12-19-2009, 08:36 PM
ss.slp.ls1's Avatar
I know that already, I was asking if you cut the LQ4 windage tray shorter, will it work...
It doesn't really matter now, I found a LS1 windage tray and used that.
Old 07-21-2011, 08:42 PM
southbaysparky's Avatar
I could still use some pics
Old 04-20-2022, 08:42 AM
monkey-leader's Avatar
Yes, you can cut the front off IOT fit the pan.
Old 04-20-2022, 09:47 AM
Received 3,022 Likes on 2,353 Posts
I think after 13 years, he might have figured something out...
The following 2 users liked this post by G Atsma:
LilJayV10 (04-20-2022), Pennywise67 (04-21-2022)
Old 04-20-2022, 10:03 AM
More for somebody that may have came here looking for an answer, but thanks for the smart reply.
Old 04-20-2022, 11:25 AM
It looked like you referring to "you", you meant the poster you were quoting, like you were directing your reply to him.
It's an easy assumption to make, worded as it is. I stand corrected....
Old 04-20-2022, 08:34 PM
dixiebandit69's Avatar
User-name checks out...
The following users liked this post:
G Atsma (04-20-2022)
Quick Reply: LS1 vs. LQ4 windage tray
