dot to dot, am I there (ls2 timing set)?
LS1Tech Premium Sponsor
Looks good to me!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Looks good to me. Just make sure you're on the intake stroke TDC & not the exhaust stroke TDC. Also, can get rid of the slack w/ a chain dampner. I know that GM Pace performance sells them & probably Tech sponsors, as well. A dampner will also eliminate chain snap.
Cam 6, Crank 12 = Intake TDC
Cam 12, Crank 12= Exhaust TDC
[QUOTE=01ssreda4;12497541]With no timing chain, the crank has no intake or exhaust TDC. The difference between intake and exhaust TDC is the cam, not the crank.
So, why assume that I meant otherwise?
Well the chain is already attached and there is a picture in the opening post......Jeez, its like talking to a fence post.
