Recommend an affordable puller for the crank pulley/balancer?
Old 11-12-2009, 07:52 AM
Jim85IROC's Avatar
Default Recommend an affordable puller for the crank pulley/balancer?
I've got my LQ9 mostly torn down to the shortblock, but I can't get the crank balancer/pulley off. My 3-fingered puller set doesn't have anything big enough to work, so I borrowed a larger one from my cousin, but the fingers just slide right off the balancer as soon as I start to tighten it.
This isn't the type of tool that I'm going to use often (or hardly ever for that matter) so I'd really prefer to avoid the Snap-On type stuff due to cost. Anybody recommend an affordable puller that can do the job well?
Old 11-12-2009, 02:22 PM
5.3LJimmy's Avatar
O'reilly sells a puller that is designed for Chrylser pulleys that works great for the Gen 3. It's not cheap though. Maybe they will do the loan-a-tool deal for it?
Old 11-12-2009, 02:32 PM
5.3LJimmy's Avatar
Here is a link to the one I'm talking about: http://www.ntxtools.com/network-tool.../OTC-6267.html
Old 11-12-2009, 10:06 PM
massls1guy's Avatar
+1 on the chrysler style puller. Autozone rents those for free.
Old 11-12-2009, 10:12 PM
XtremeDime's Avatar
I bought a 3 jaw pulley for like 15$ from schucks.
Old 11-16-2009, 12:14 PM
Jim85IROC's Avatar
Borrowed a kit from Advance Auto that had that chrysler-style puller. Other than not having a long enough rod to slide into the crank bolt hole, it worked nicely. Thanks for the advice!
Old 11-16-2009, 03:57 PM
LSX Mechanic
Damian's Avatar
Most of the elcheapo generic pullers will get it off. I just wouldn't use them over and over again. I abused/destroyed 2 cheap pullers before biting the bullet (and bending over) to buy a Snap-on puller.
If you're a weekend warrior or only using the puller once, a $10-15 puller at Autozone will work just fine.
Old 11-16-2009, 05:45 PM
Hamrdown's Avatar
Just rent one. No need to buy one unless you plan on doing this many times.
Old 11-16-2009, 06:29 PM
OUTLWZ's Avatar
I just used 2 J-hook prybars.. Came off with ease.
Old 11-16-2009, 11:17 PM
printmanjackson's Avatar
can you not rent the tool to remove the balancer AND install the new seal from AutoZone?
Quick Reply: Recommend an affordable puller for the crank pulley/balancer?
