Looking for good reusable head bolts.
Old 11-14-2009, 08:15 AM
tennerv8's Avatar
Default Looking for good reusable head bolts.
Can somebody recommend a good reusable set of head bolts? Just something other than tty bolts. Need to fit a 6.0 with L92's. Thanks fellas.
Old 11-14-2009, 08:53 AM
PREDATOR-Z's Avatar
Arp....
Old 11-14-2009, 09:18 AM
KJ@DHRC's Avatar
ARP is the way to go for sure!! I have a set in stock and could ship them out for you on Monday!! $139.95 shipped to your door!! Email, PM or give me a call and we will get them on the way!!
Old 11-14-2009, 09:40 AM
tennerv8's Avatar
Do you have the model number? Will the fit a 6.0 with L92 heads?
Old 11-14-2009, 10:00 AM
Unertl42's Avatar
I would say get ARP head studs, then if you ever switch heads, you don't have to worry about coolant in the bolt holes, and it's a lot easier
Old 11-14-2009, 10:05 AM
01ssreda4's Avatar
as stated, ARP
Old 11-14-2009, 10:30 AM
tennerv8's Avatar
Not trying to spend $400 on head studs, just some quality bolts.
Old 11-14-2009, 10:51 AM
Sk8phreak88's Avatar
Then go with the ARP bolts as suggested..
Old 11-14-2009, 02:34 PM
KJ@DHRC's Avatar
I am not in the office today so I don't heve the exact part number. I believe it is a 134-3610 (I think). I can double check this on Monday. oh and yes they will work just fine using L92 heads on your 6.0 block!!
Old 11-15-2009, 08:38 PM
Mighty-SS's Avatar
ARP Bolts FTW !!! I have a set of barely used ones for only $95 !!!
Let me know if interested
Old 11-15-2009, 09:54 PM
Rddragon's Avatar
You are not supposed to "reuse" head bolts. They are torque to yield bolt so when you tighten them they stretch to have an elastic effect to pull the heads to the block. Once you tighten a torque to yield bolt once, it is unsafe to pull them off and retighten them again. That is why head studs are great, you can reuse them. Plus head studs have a better clamping effect than a bolt.
Old 11-16-2009, 09:24 AM
KJ@DHRC's Avatar
ARP head bolts can be reused just as their studs can. The torque to yield bolts are GM. As long as you are using ARP you can reuse them.
Old 11-16-2009, 11:11 PM
Rddragon's Avatar
Are ARP bolts just normal bolts then?
Old 11-16-2009, 11:25 PM
mwatson185's Avatar
They are quality bolts with high tensile strength. I'm not sure what a "normal" bolt is, but if you mean non TTY then yes, they are normal.
Quick Reply: Looking for good reusable head bolts.
