Valve springs for my cam swap
Old 11-26-2009, 09:20 PM
4Birdman's Avatar
Default Valve springs for my cam swap
236/242 .580/.590 with 112 LSA
School me here, what would be a good spring to go with?
Motor is stock, with a PP Typhoon intake. It is now a 6-spd car.
My oil pump is going south, so figure it is time to take care of the intake and cam swap.
Old 11-26-2009, 09:36 PM
BaddBird's Avatar
PAC 1218s
http://sdparts.com/details/pac1218
Old 11-26-2009, 09:48 PM
copteezer496's Avatar
I have a set of springs that i just took of that will hold up to a 609 lift cam. I had it on my 236/236 585/585 @ 112 LSA cam. I up graded to a 239/242 643/609 @111 LSA cam so i needed to go with the PRC Gold double springs. If you're interested in my old springs, we'll work something out. They only have about 10,000 miles on them (mostly highway). I just took them off last weekend.
Old 11-26-2009, 10:00 PM
01ssreda4's Avatar
I would run a double spring with that cam, but thats just me.
Old 11-26-2009, 10:10 PM
BaddBird's Avatar
Isn't that kind of overkill with a .580/.590 lift
Old 11-26-2009, 10:23 PM
printmanjackson's Avatar
what would be wrong with running too much spring?
Old 11-26-2009, 11:01 PM
01ssreda4's Avatar
In some's opinion yes. I run a single spring on my tr-224 with .564 lift. But I believe 918s until just recently were only good to .600. Now I believe they say .625 but thats under optimal conditions. I say be safe, not sorry.
Old 11-27-2009, 09:56 AM
Ed Curtis's Avatar
Interesting... 242* at .050" tappet lift with .590" gross lift... Looks like a square lobe that actually needs more spring rate than what most people would think.
Old 11-27-2009, 10:28 AM
00 Trans Ram's Avatar
I'd stick with something that has been proven under race conditions. Which is what I did.
Comp Cams - 925-16
Tested for a year in the LS-engine Nascar series (ASA). These were the spec valve springs, and they performed great.
They also have 926-16 which can handle a bit more lift.
Old 11-27-2009, 10:48 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
Looks like more spring pressure is a good thing in that lobes case.
Manley has a nice one. still a single spring, and will work with stock locks and retainers (but i would go TI retainers and their tool steel locks if it were me)
Springs are $200 for the set. A little pricey yes, but its an awesome single beehive spring made by manley. their new nextek design.
pressures are 150@ 1.8 355@1.200 max recommended lift is .600 coil bind at 1.085
a bit stiffer than the pac 1218.
Quick Reply: Valve springs for my cam swap
