Ms4 with stock heads
Old 12-01-2009, 09:13 PM
krissoto's Avatar
Default Ms4 with stock heads
I have ordered an ms4 with 111 lsa. I'm just wanting to make sure that it will work with stock heads. I don't want to flycut my pistons and I don't think I will have too but some post on here are really confusing so I'm just asking. I have a 00 ws6
Old 12-01-2009, 09:14 PM
Gordon0652's Avatar
Yes i did.
Old 12-01-2009, 09:20 PM
wildn347's Avatar
i ran the ms4 on my stock 241 heads and it was fine.. make sure you upgrade your valve springs or the valves will touch
Old 12-01-2009, 09:35 PM
ryarbrough's Avatar
YOU NEED TO MEASURE!!!
Don't rely on what worked on someone else's motor. There are tons of variables that can mean the difference between this working and you tearing up a motor. I'd be willing to bet that it'll be really tight either way.
Old 12-02-2009, 02:51 AM
krissoto's Avatar
Thanks for the info. Upgraded springs are a definite and also will be sure to measure.
Old 12-02-2009, 08:44 AM
FasTimeSS's Avatar
It will fit I have MS4 with PRC LS6 heads and it clears just fine. I would messure to make sure you get the right pushrod length. Good luck
Old 12-02-2009, 09:55 AM
Jon@Texas-Speed's Avatar
Yes it will clear without an issue. You will not have to flycut. I would get the PRC EHT dual springs and chromoly pushrods with the cam. The springs will support the lift on the MS4 and last for much longer than the popular .650" springs on the market. Like mentioned above, it is always good to degree the cam in and measure PTV prior to firing the engine. Let us know if you have any other questions and we'll get you fixed up!
Jon
Old 01-04-2010, 10:16 PM
NAVY99B4C's Avatar
Great info! just what i was looking for!
Old 01-04-2010, 10:23 PM
223HAWK's Avatar
Bonne Terre, MO WTF is that? Never heard of it..
Anyway..MS4 Herrrree..No Issues..other than its a loud **** now and sounds like a race car
Old 01-04-2010, 10:26 PM
02*C5's Avatar
^^^^ I agree 100%
DO NOT TAKE ANY ONES ADVISE!!! Measure and make sure, secondly make sure you upgrade valve springs and you might want to do lifters also if yours have more than 50K miles. You will also want to do push rods. With push rods you also want to measure and get the correct sized PR. An oil pump is also in the works if the one your engine has, has more than 80K miles.
Its your engine your valve train your pocket.
Old 01-04-2010, 10:30 PM
223HAWK's Avatar
Probably wouldnt hurt to do some bigger injectors at the same time..42lbs to be safe..More than likley it will run lean up top..wont take that too long..
Quick Reply: Ms4 with stock heads
