Compression vs Pump Gas
Old 12-05-2009, 11:23 PM
Restricted User
Zero4488's Avatar
Default Compression vs Pump Gas
Alright...so I realized that my cam swap isn't going to be so simple...since I'd have to fly cut a decent amount I decided just to go with a set of pistons. Now my question rises....I'm looking at getting the diamond high comp dome pistons. I'd also like to mill my heads, now without milling my 66cc heads I'd be at 11.5:1 if I milled them to a 62cc I'd be 12.2:1, will the 12.2:1 still be streetable? Can I still run pump gas efficiently? With that compression would I see gains running a higher octane? I'd like to get answer to these questions before I make up my mind. Also if anyone has any input on bumping the compression in a stock bottom end motor please let me know....
-Dave
Old 12-05-2009, 11:29 PM
G Engines's Avatar
If you try to stay @ 12.0 to 1 you can run pump gas any higher you risk detonation.
Old 12-05-2009, 11:57 PM
Restricted User
Zero4488's Avatar
So anything over 12:1 on pump is risky?
Old 12-06-2009, 11:30 AM
BriancWS6's Avatar
When your cutting it that close it depends on more than just the static CR.
Is the pump fuel in your area 91 or 93? What will your quench be? A tight quench helps to ward off pre-ignition.
Also keep in mind there will be a line that you can cross where higher compression with pump fuel will require a softer timing table which will cost you potential power.
I personally ran 11.34-1 on a stock bottom end heads/cam setup for nearly 3 yrs. It never saw an ounce of race fuel or fuel additives, and it never had any issues with 93 pump fuel with 28 dgrees of timing. My quench was tight at .032-.033 and I also ran the proper heat range plug (imo), which was a TR6.
What do you use the car for? Daily driver? Weekend car?
Old 12-06-2009, 06:53 PM
Restricted User
Zero4488's Avatar
I've done alot of reading on static and dynamic compression but still just can't seem to grasp the concept of each and how to calculate each. What exactly is quench? Is that the amount of time the piston is at TDC? I'm not worried about the 11.5:1 compression...it's getting it up into the 12's is my concern....What do I need to figure out my static and dynamic compression? I can PM you my setup if it will help to figure it out....
Old 12-06-2009, 07:22 PM
BarneyMobile's Avatar
Its not so much static compression that you have to worry about for running pump gas. Dynamic is what your worried about. Dynamic compression is measured once the intake valve is closed. For example, lets say the intake valve closes 25* after bottem dead center. That means the piston is on its way back up on the compression stroke before the intake valve is fully closed. The A/F mix is not being compressed until the intake valve is closed so that means your dynamic compression is always gonna be lower than static.
Quench is the measurment between the piston and the cylinder head when the piston is at TDC.
Old 12-06-2009, 11:20 PM
BriancWS6's Avatar
The valve events of your cam play a major role in your DCR. Do you know the cam that you are going with and it's specs? Post them up and someone on here that can use the calculator can punch in the numbers for you.
As far as quench goes, since the LS1 pistons, at least stock ones, come out of the hole ~.007-.008, you have to subtract this value. So with .040 gaskets, you'd be at .032-.033 for your quench.
The tight quench helps by forcing the air/fuel charge into the combustion chamber, which helps to even out the temps and hot spots. It also helps to mix the air/fuel charge making it ignite easier.
Old 12-06-2009, 11:55 PM
Restricted User
Zero4488's Avatar
The cam specs are 236/249 .647/.614 112+4...I have the cam sheet I can copy that and upload that if you need more information on it....
Old 12-07-2009, 12:56 AM
Sid447's Avatar
Smile
Just post the valve events from the cam card...
e.g.
Intake Opens @ ....* ATDC, Int Closes @ ....* ABDC
Exhaust Opens @ ....* BBDC Exh Closes @ ....* ATDC
Someone will be more than happy to help you out.
Old 12-08-2009, 04:23 AM
Restricted User
Zero4488's Avatar
My cam sheet gives me a bunch of ATDC and ABDC numbers...which ones do I use?
Also quick side question....do you have to clearance an LS1 block for a 4.000" crank?
Old 12-08-2009, 01:43 PM
ViaBellator's Avatar
On your side question, the answer is..."maybe" Some need it, some don't. Mine did not need any clearancing for a 4.00" crank, but I know of a few people that did need to clearance a rod bolt or two.
Old 12-13-2009, 11:52 AM
Restricted User
Zero4488's Avatar
Thanks...still don't know which ATDC and ABDC numbers you want...
Old 12-13-2009, 12:22 PM
tom falco's Avatar
DCR is the key. If the valves dont close the compression preasure is O. Did you advance that cam?? Your sheet points out a 112 +4. I am saauming it is advanced. If so that is not what you want to do. The cam is pritty up there so i think you will be OK. TOM
