should I reuse my PRC duals on my new heads?
I got some Trickflow heads that I plan on using in the spring, but they have no springs. I installed a new set of PRC duals in my stock heads, they have about 10,000 miles on them. Would I be ok just reusing them or should I get new ones?
if it was me i would go ahead and get new ones cause i would kill myself if a spring gave out because there old and i end up trashing a trickflow 215 cause there a decent amount of $$$$
You could probably reuse those springs if you wanted to and not have an issue at all. We have customers with MS3 cams with 25k+ on those springs without an issue at all. If you were going to replace them I would go with the PRC EHT dual spring. They are probably the best dual spring to fit in the stock pocket on the market. We have tested them against several of the leading valvesprings on the market and they will far outlast any of the popular .650" dual springs on the market today! You also won't see the spring sag like the others with this spring as well so your seat pressures won't drop. Shoot me a PM if you have any questions!
Jon
Jon
LS1Tech Premium Sponsor
As a note, you'll need a different spring seat than our kit comes with for that aftermarket casting head. It has a larger OD valve-guide (well, not the guide really but the meat around it).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
