While staying emissions friendly (read: non-agressive cam), gains on a 383ci?
Old 12-21-2009, 11:13 AM
Lopoetve's Avatar
Default While staying emissions friendly (read: non-agressive cam), gains on a 383ci?
So I have to stay emissions friendly for CO. that's not super hard with a properly running car with Cats, but the one key is I can't get to aggressive with the cam - that blows over the limits every time.
On top of that, I've always wanted to build a 383 (I'd probably start with one of the TSP short blocks, add heads/etc to it, with a fast 92 intake and a ported TB). I don't know why, but I have Goal is a mid-range power build (the car is built for handling, not drag). What can I reasonably expect to get with a 383, running compression appropriate for 91/93 octane, with a non-aggressive cam, and full bolt-ons?
Old 12-21-2009, 11:51 AM
teke184's Avatar
with the right heads you should be able to make a very torquey engine, which will be great for coming out of curves at slower speeds.
talk to Predator-Z or Pat G. about a custom cam...they'll set you right up.
it will be the BEST way to get to your goals...and still be sniffer friendly
Old 12-22-2009, 04:00 PM
hawk1125's Avatar
kinda curious about this myself
Old 12-23-2009, 12:59 AM
Lopoetve's Avatar
I'm gonna talk to clint at AIR - he's the local guy, but with coloradolsx gone, it's kinda weird right now.
Old 12-23-2009, 04:26 AM
PRE-Z06's Avatar
I would venture to say an XFI 230/230 115+4 with zero overlap would pass the sniffer in a 383 and make close to 500rwhp with some TF 215 heads
Old 12-23-2009, 07:23 AM
9secondsflat's Avatar
check out lingenfelters site, all their 383 cam's pass carb standards
Old 12-24-2009, 01:10 AM
Lopoetve's Avatar
Trick flow? I hadn't looked at those - I'd been looking at the AFR 215cc heads actually - any thoughts between the two?
Old 12-24-2009, 01:12 AM
Lopoetve's Avatar
carb sadly doesn't always mean sniffer, but I'll check.
