Best Budget H/C setup for your buck
Im wanting to do a cam and kinda want to do heads also.
looking for a 10 second motor pass. supporting mods in sig. going to add 3.73's and a ram air kit then heads and cam.
http://www.speedinc.com/cont.cfm?cid=C0000984#
this ram air kit is what you want if you are losing the ac...great bang for the buck...
Dang man your stuff must really work speedinc got your products going now. Oh yeah what heads are on your car 243's?
Ok if i do pick up a set of stock 243 or 799's what all do you guys recommend me doing to the heads? If i do this ill probably be going custom cam. Keep my LS6 intake and ported t/b. Will i need injectors also i sure hope not cause of $$$
it takes quiet a bit to get into the 10's you need to trap at least 121 and 60' in the 1.40's!
spend the money on the heads gettings worked on because a decent cam and decent heads wont get you in the 10's.
there is a few 10 second a4 camaros such as chris up there but like i said theres only a FEW!
btw spend the 150-200 bucks on that ram air that chris1313 sells, its and awesome product and can give you an extra 2-3mph. best bang for the buck!
If you are on a budject just get a good valve job and mill the heads(59-60cc)...that will give great gains, and thow in a healthy cam, doesnt have to be huge to run 10s as i am proof of that, i went 10.81 in -400 da air at 3250 raceweight with my stock 10 bolt and 3.23 gears with a ls6 intake...i added the 4.10s aluminum spool and ported fast 92 with -900 da(better) air and only gained .2 tenths for about $3,500...but i didnt feel like rebuilding the 10 bolt so it was bound to be replaced sooner or later...i would look into yank too i absolutely love their ss4000 converter, hopefully it still performs just as good with my new heads and cam package come spring...fingers crossed...
edit just saw you have the ss4000
i have a buddy with a m6 stock 243s and a big vindicator cam and he pulled off a 10.88 at 127mph in great air, now this would be more in the 10.50s with a a4, but he has all the extra goodies like a ported fast, electric water pump, and my ram air on there...
Yeah chris after posting that last night i got to thinking. Instead of spending the $400-$600. on some heads and then having them worked. I can just get your cam and springs when you pull it out. Then use the head money for your ram air kit, some 3.73's and little more suspension. Going to the track tomorrow to see if it can pull off some 11 sec SI passes. Then i can go from there.
yeah with my cam and the ram air that is going to be around a 75rwhp+ gain, i can even include the pushrods too for a package deal since i need longer ones for my TFS heads......i will let you know when i get it out...
i wouldnt waste the money on the gears, they are not going to give that much of a gain at all...less than a tenth, that i what i saw and i went to 4.10s...the stall makes up for the gear in a4's...trust me keep the 3.23s make that one of your last mods...or wait until you get a built rear...
