whats a lot of miles for a ls1
I'am just going to use the engine to drive the car and leave it stock other then headers and a stall till i build the other engine. I just dont want to buy one with high miles and have it die in a few weeks . No need for two dead engines.
Mine is 182 k and planning on doing a h/c on the engine have it as dialy driver motor runs strong oil pressure above 40 at idle psi and adding every 2. Month a compression restore bottle and z max also this month
My SS has 126k on it, its still like a new car.
I agree that 200k plus miles isn't a problem on these motors. Seems like the trans (either one) takes a crap way before the motor if you take care of it
As of now it is still up in the air, waiting to see what the Ins. says. Probably part out, or better, sell as a whole.
If you're going to just leave it stock, you could go with a 5.3 for around $500 to keep it mobile on the cheap.
SO what are you really asking here?
Are you trying to set a limit on mileage to the engine you buy?
The thing is the engine is only as good as it was taken care of. If someone didn't change the oil and thrashed it, it could be ready to crap out at 60k miles on it or it can run with good maintenance for a very very long time..We've seen 200k on this board many many times so.... that I am saying is there are no guarantees with a used engine as to how long it will last. You cant tell by the mileage if its been abused and neglected.
