lifter and springs help
Old 12-28-2009, 04:50 PM
linebacker50's Avatar
Default lifter and springs help
ok im buying with my xmas money a 228R cam. but i dont know which lifters or springs to get. i have heard stay away from the 918 springs but then others have said they work just fine. also im looking for new lifters that wont kick the **** outta my wallet. also if you could gimme some links to what your recommending that would really help me out. thanks
the car is my DD, its a ls1 with LT headers, lid, ls6 intake, and a cut out. i will eventually get a stall when more money comes my way. but again with that idea i've heard having a stall and it being ur DD is not a good idea. dunno but thats a diff. topic.
Old 12-28-2009, 05:31 PM
DSkyles's Avatar
Old comp 918's used to break, but they redesigned them now and they are fine. I would use those or the PAC beehive springs.
LS7 lifters will work fine with your setup. They are about $130.
Old 12-28-2009, 06:32 PM
vettenuts's Avatar
Just want to verify that you know the heads require removal for the lifter swap. Also, PAC 1218's or 1518's would be my first choice.
Old 12-28-2009, 06:54 PM
SOMbitch's Avatar
All good advice above. If you decide on the PAC's the 1518's are worth the extra $$$ because they are nitrided and will last longer than the 1218's. Any of the PP or PRC doubles will work well too but add a little extra valvetrain weight.
And you will be doing yourself a big favor by doing a stall first before dropping in a cam that size. Consider start collecting parts and installing all at once so you only have to have to tune once.....
Old 12-29-2009, 10:09 AM
i dont have a choice but to change the lifters if im getting a cam. because the old lifters form to the stock cam and if i use them they will mess my new cam up. so hear atleast...
Old 12-29-2009, 12:57 PM
thunderstruck's Avatar
that was true for a flat tappet cam, not true for lsx engines
Old 12-29-2009, 02:12 PM
vettenuts's Avatar
How many miles on the motor and what is the new cam?
Old 12-30-2009, 08:59 AM
the car just rolled 127 when i put it away for the winter. and its the 228R cam. also i would like more people to comment on the do i need lifters or not. not that i dont believe you thunderstruck but i would rather be safe then sorry with more input. thanks
Old 12-30-2009, 10:19 AM
vettenuts's Avatar
That's a lot of miles. I would do the lifters and maybe clean up the heads while they are off and lap the valves back in. Nothing major, but a good clean with valve lapping and new valve seals.
Old 12-30-2009, 11:32 AM
damnit.... these motors are a bitch to work on from on top...
