From what are this ARP head studs?
Old 01-14-2010, 05:35 PM
El_TransAm98's Avatar
Default From what are this ARP head studs?
I bought this from a friend and I wanna know if this will fit to my ls1 motor I try a search but never found out if u can tell me plz from what motor are this can be used!!
Old 01-15-2010, 07:38 AM
KCS
Moderator
KCS's Avatar
Looks like a head stud kit for an older LSx (<'04), but can't be sure. There should be a different number on the box, like 234-4110.
Old 01-15-2010, 07:53 AM
G Engines's Avatar
Thats for the early ls blocks they use the long studs the newer blocks all the studs 7/16 studs are the same length
Old 01-15-2010, 08:32 AM
KCS
Moderator
KCS's Avatar
You mean 11mm?
Old 01-15-2010, 09:20 AM
But will this fit my ls1 I just bought them without the box... I just wanna know cuz I want to sell them have no need for them and wanna find out what fits so I would know to sell them!!!
Old 01-15-2010, 09:42 AM
KCS
Moderator
KCS's Avatar
No one here can tell you for sure, at least not with the limited info that you have. You need to measure the studs, thread pitch/spacing, and compare that to what an LS1 kit would be. From the picture you posted, it looks like an LS1 head stud kit, but we can't be certain until the important measurements are established.
I'm pretty sure they should be an M11 (~.433") diameter with a 2.0 thread spacing, and the small ones should be M8 (~.315") with a 1.25 thread spacing.
Old 01-15-2010, 02:12 PM
I got a paper that says 7/16 and withstand 200,000psi
Old 01-15-2010, 02:20 PM
vettenuts's Avatar
Where are the nuts and washers?
Old 01-15-2010, 02:35 PM
I got everything but didn't post all the things
Old 01-15-2010, 04:36 PM
KCS
Moderator
KCS's Avatar
What paper?
All Gen III/IV engines are metric, not standard thread. A 7/16" stud/bolt probably wouldn't even thread into the head bolt holes.
Old 01-15-2010, 05:02 PM
vettenuts's Avatar
I thought the upper half of the stud was SAE, not metric.
Old 01-15-2010, 05:06 PM
XtraCajunSS's Avatar
That is a pre 2004 LS head stud kit. If it came with 6pt nuts, it is a 234-4110, if 12pt nuts then it is a 234-4316.
Shane
Old 01-15-2010, 07:02 PM
Yeah thanks the nuts are 12 points
Old 01-15-2010, 07:03 PM
KCS
Moderator
KCS's Avatar
It could be, I don't know for sure. It doesn't really matter, as long as the portion that threads into the block is correct, and that's the portion I'm talking about. The threads in the block are metric, so the threads on the stud need to be metric as well. I've made the mistake of using an SAE bolt in a metric threaded hole, and it required a helicoil to fix.
Old 01-16-2010, 07:40 AM
vettenuts's Avatar
I honestly never checked the thread but it would make sense that the upper threads are SAE. Also, I used an SAE 12 pt socket, 1/2" if I remember correctly but its been a while.
Old 01-16-2010, 10:31 AM
KCS
Moderator
KCS's Avatar
It very well could be, I've never measured either. It sure is a hell of a lot easier finding SAE threaded fasteners. When I made my own "Tim's Tool" to swap valvesprings, the closest place here in Houston that sold metric threaded rod was nearly 30 miles away.
Old 11-01-2010, 10:09 AM
01ssreda4's Avatar
Bumping this back up, the threads at the top of the stud are what? 7/16th 20?
