Who ports heads? Manifold?
Ok i'm looking to get some more out of my car. I do'nt need more then 430-450HP. I have LT's, LS6 manifold, 236 cam. Is it worth it for me to get my LS6 intake ported for the money and who does it? Also besides TEA who ports 243 heads? i have a set of 243 heads so I figured it was more cost effective to just have them ported rather then buy new ones. what do you guys think?
LS1TECH Sponsor
We can get you setup with some of the best flowing heads for the given port volume. Give me a call tommorrow and I will get you a quote.
Flow Chart Stage 3 LS2 / LS6 (243 Castings):
LIFT 0.1 0.2 0.3 0.4 0.5 0.55 0.6 0.65
Stck LS6 210CC
61.2 135.1 191.5 232.4 250.2 251.1 252.7 252.9
LS6 STAGE 3 INT 215CC
69.1 141.2 199.6 246.2 288.8 305.8 314.6 318.7
Stck LS6 210CC
a set of 243's with the proper work can be a nice piece. if your serious about getting some work done to a 243 shoot me a pm or call one of the board sponsers up. i know a local to us guy that does top notch work. if your in a rush he probably isn't an option because he is always booked.
LS1Tech Premium Sponsor
We offer the PRC CNC Porting for your castings, or we can supply you new heads. The PRC Stage 1 for ls6 heads would cost just over 1000 a pair brand new or right at $700 to fully machine & reassemble your castings. Checkout www.texas-speed.com or look in the dyno section. That's the best way to see the proven performers.
stg1
http://www.texas-speed.com/shop/item...d=649&catid=20
stg2
http://www.texas-speed.com/shop/item...d=134&catid=40
stg1
stg2
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Check into a fella named Jeremy Formatto I believe is His name, I have seen him on this site, He is known for porting manifolds, I read an article In High Performance Pontiac where they had him port a GTO manifold and it picked up some good numbers.
As far as Heads Go, I have a set of PRC heads from Texas Speed. They work terrific, and you are not going to beat their prices, If you are on a budget.
Within about 50 miles?
are my numbers not holding out? I was thinking that is how much power i would make with this but i could be wrong. I don't need to go anymore power then that for the street.
You can make that kind of power no problem. Let us know if you'd like to discuss the PRC head options!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
