Estimated labor costs for a head/cam swap?
Old 01-27-2010, 03:51 PM
gateman's Avatar
Question Estimated labor costs for a head/cam swap?
What would be a good estimate (labor only) to install a set of AFR's, cam and replace injectors from the local speed shop?? Thanks..
Old 01-27-2010, 04:15 PM
transam69230's Avatar
I am going to guess anywhere from 1200-1500. I would think that the shop would go by flat rate, and then charge you whatever is necessary if there is more time that is needed to complete the install.
Just do it yourself, it is a fun experience and you will learn a lot about your car!
Old 01-27-2010, 04:57 PM
j_dover's Avatar
its free if you do it yourself lol
Old 01-27-2010, 06:48 PM
gateman's Avatar
not if your own labor rate is 60/hour and you have all the work you can handle..
Old 01-27-2010, 06:51 PM
02*C5's Avatar
You know what they say a mechanics car is always broke
Old 01-27-2010, 06:53 PM
FoFittyFoSS's Avatar
All the shops around here charge more than $60/hr labor rate plus shop supplies, taxes, and other BS. But I can understand if you are swamped and need it to drive. My cousin has a shop and a labor guide if you need me to look up the flat rate hours and get an estimate for the job just to give you an idea I can. I would guess, looking up head gasket replacement and maybe doubling it for non stock heads and cam. Just a guess though.
Old 01-27-2010, 08:00 PM
CamdLS1'00SS's Avatar
i paid $2500 for labor to do a cam, valve springs, timing chain, clutch, intake, hook up a GM tuner to the ECU, ring and pinion swap, and basically bathe the heads in brake cleaner...thats at $90ish an hour though, shop rates are more than likely different down your way
Old 01-27-2010, 10:43 PM
hcb1700's Avatar
You should be looking at around $1500 for the job. This is off of a quote I got when I asked a shop. I just ended up doing it myself, and saved myself the $1500 for more goodies.
Old 01-27-2010, 11:18 PM
Titanws6's Avatar
I'd say around a $1k+ without a Tune. All depends how good the workmanship is of the shop. I was quoted $1500 with a full tune, so I did it myself. Granted took my time, sounds like for you time is money. At $60/hr, it would be cheaper to do it yourself.
Old 01-28-2010, 07:30 AM
99corvette's Avatar
Hell we would do it here for about $700
Old 01-28-2010, 09:15 PM
gateman's Avatar
Thanks for the replies.. Local speed shop is a little slow right now and they are good friends, probably just drop them a grand and pay for all the supplies.. they typically only charge 50/hr..
Old 01-28-2010, 10:24 PM
D.Jones's Avatar
Expect to pay around $1500 plus the cost of your parts, that's the qoute I got. I am bout to do h/c, ls6 intake, LT headers, motor mounts, and catback all at the same time to make it easy.... I'm just waiting on the h/c. I plan on doing it myself with the help of a friend to save money and have a fun experience. This will be my first time doing major work on the car and ls1-how-to has a great write up on a h/c swap. Just do it your self man and save the money for a rear end : )
Old 01-28-2010, 11:21 PM
Sk8phreak88's Avatar
I charged my a buddy 250 bucks and a few cases of beer to do his heads/cam and stall in his 04 gto.. :idk:
Old 01-29-2010, 08:30 AM
SUG
SUG's Avatar
I used to be a fan of do it your self.. but then when youhaven't done it be fore and you screw something up.. then you gotta buy the parts again then pay someone else to do it.. I'd rather pay someone that konws what their doing then if something happens take it back to them to fix it... imo... but to answer your question, everyone is right about 1000-1500 depending on where your at.
Old 01-29-2010, 09:10 AM
matrik's Avatar
1K-1.5K for sure.
Old 01-29-2010, 09:34 PM
jcobra99's Avatar
1K < Labor
Quick Reply: Estimated labor costs for a head/cam swap?
