Which windage tray?
Old 02-06-2010, 10:58 PM
Loudpipe's Avatar
Default Which windage tray?
Im putting a 6.0 in my camaro and just shelled out the $ for an f-body ls1 oil pan and pickup tube. Can i use the factory 6.0 windage tray or do I need to find one out of a ls1? Any input would be great!
Old 02-07-2010, 06:47 AM
Unertl42's Avatar
you'll either have to trim the LS2 windage tray, or get one out of a camaro. I just did mine yesterday
Old 02-07-2010, 09:11 AM
Loudpipe's Avatar
What do you have to trim?
Old 02-08-2010, 09:45 AM
Loudpipe's Avatar
bump for an anwser
Old 02-09-2010, 04:50 PM
Pocket's Avatar
Trim the front off to clear the pickup tube
Put it on there and youll see it
Old 02-10-2010, 09:26 AM
BoostedLade's Avatar
or you can buy some washers to space it out so it will clear it.
Old 02-10-2010, 09:38 AM
Jon@Texas-Speed's Avatar
For not more than they cost, I would just buy an F-body tray. That is unless you are trying to get it assembled today and the dealership doesn't have one.
Jon
Old 02-10-2010, 09:43 AM
Reaper SS's Avatar
The washers will clear the rods on a stroker application but the 6.0 long style windage tray will not clear the front raised area of the F body oil pan it will not allow the pan to sit flush to the block.
The front section of the pan is raised to clear the K frame and pushes the pan too close to the rotating assembly that some stroker setups need to clearence the pan for the #1 rod bolt so the front part of the windage tray has got to go when using a stock F body pan.
