Another "help me pick my cam" thread
I know this section is full of threads with guys who have no idea what they want in a cam... well count me in. I've got a 98 Trans Am that I am wanting to break into the 11's this season, the lower the better, with some ported heads and a cam. I know it can be done, but I don't know what cam would be best for my setup with the single plane intake, and I could use some help. I'm not necessarily interested in a dyno queen where the numbers look good but the usable power is too high in the RPM to be of any use. Rather I am looking for the quickest ET. It'll be a full weight car on Mickey Thompson DR's.
What Cam would work best with this setup?
The car has:
Lid
Long tube headers with dual cutouts
rebuilt trans with TCI race kit
4.11 rear gear
SFC's
LCA's
Plans for the winter include:
Cam (to be determined)
Milled and ported 241 castings - milled .030 and should flow ~315-320 when completed
.040 compressed thickness Head Gasket (milling and gasket should land CR ~11.x:1)
Super Victor EFI intake manifold
4150 style throttle body
3600 lock up converter
Injectors??
Any Help is Greatly appreciated.
The car has:
Lid
4.11 rear gear
SFC's
LCA's
Injectors??
thunder racings trak cam is very good daily driver/weekend track car cam, Futrals F-14 is about the same a friends of mine has stock heads with a f-14 built 4l-80 4.10s and full bolt ons and runs 11.7 all day both of texas speeds torquer cams are all right there too, texas speeds tsunami cam is a little bigger but the lift is high i dont know if it would work being that your heads are milled you would have to call them. thunder racings raptor cam is also good the first car they put it in has stock ls6 heads and ls6 intake full bolt ons with the raptor cam and runs i think consistent 11.6s leaving soft.
that's exactly what I was thinking... and it's a Super Vic, not a Vic Jr.
Where would be a good place to start to get a custom cam speced out? I sent Patrick G a message the other day and haven't received anything back.
The car has:
Lid
4.11 rear gear
SFC's
LCA's
Injectors??
The car has:
Lid
4.11 rear gear
SFC's
LCA's
Injectors??
LS1 Tech Administrator
Do you plan on fly-cutting your pistons? If not, you will be limited on how much duration and overlap you'll be able to run. Keep in mind, a single plane intake will want to peak around 400-500 rpm higher than a factory EFI intake. If you want to keep your power peak down, you'll need to select a cam with appropriate valve events (especially the intake valve open and close ) to hit the power band that you're wanting.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
