Is there a LS specific cam degree kit?
Moderator
To change the installed centerlines of a cam, you'd have to have an adjustable timing set. The lower gear would typically be marked so that you can advance or retard the camshaft in increments of 2 degrees.
Moderator
That's why I said typically the lower gear is marked. The only ones I've seen with the adjustable top gear are the Cloyes, and belt drives. Rollmaster, NMotion, Manley, and Pro Gear all have the bottom gear indexed. I think the Comp timing set does too, but also incorporates an offset bushing.
I found this. It comes with the LS socket and other stuff.
http://www.cpgnation.com/forum/comp-...t-gm-3653.html
