Ticking Noise, any opinions
heads/cam install a few weeks ago, hasnt been driven much, noticed ticking noise sounds like its coming from passenger side of engine bay. Its consistent with engine speed but not constant, it only ticks every few seconds or so at random when engine is idling. Im guessing a loose rocker, I am going to check the rockers tomorrow or thursday when i have time, I jsut wanted to get a few opinions before.
check rockers, pushrods, if it looks good, change to a heavier oil.
i had a ticking for the last 1500 miles, checked rockers/pushrods, changed to 20w50 friday and then the motor started knocking yesterday, great!
Ok, so i found a small (or so i thought) leak between my header and my head after i posted this thread. When i had gotten my y pipe built, the guys at the muffler shop were yanking and pulling on my header turn downs trying to get them off (clamped on for temporary driving), apparently they had pulled a couple threads out of a couple of the header bolts on the passenger side, the bolts that came with my headers werent very long anyway. So i got a new gasket and longer bolts today and fixed the leak, which was also the source of the "ticking" noise. The leak, i thought was just a little hole, but after i got the old gasket off, i discovered that almost one whole port was leaking.
Smell? Or is there some method?
Well mine was at the front port on the passenger side, and i just happen to stick my hand in there and felt it blowing on my hand when it was running. But i noticed after it had been ran for a little bit, it left a smoke stain on the side of my head where it was leaking.
