stock length push rods
Old 04-05-2010, 11:16 AM
JeaneGrae's Avatar
Default stock length push rods
what is the length of stock ls1 push rods? Looking to replace them with head swap
Old 04-05-2010, 11:36 AM
01ssreda4's Avatar
Closest you can get is 7.400.
Old 04-05-2010, 11:45 AM
racer7088's Avatar
Or 7.375.
Old 04-05-2010, 05:06 PM
vettenuts's Avatar
I came up with 7.385" for the stock length when I measured them a few years back. I think the diameter might be slightly below 5/16" as well.
Old 04-05-2010, 06:42 PM
SOMbitch's Avatar
vettenuts is correct on the length. Never measured the diameter just always asssumed 5/16's....
Old 04-05-2010, 06:49 PM
racer7088's Avatar
Yes and the 7.375 actually measures about 7.390 end to end that's why we use those a lot.
Old 04-05-2010, 11:13 PM
JeaneGrae's Avatar
Default upgrade
When upgrading will the 7.400 cause any problems? Any recommendations?
Old 04-06-2010, 04:38 AM
vettenuts's Avatar
Before you dis-assemble the motor you may want to take a measurement. As I recall the stock setup was close to 0.100" preload so the slightly longer 7.400" may put you over 0.100" preload (although a couple of vendors have told me they have seen better power set deeper). If that is the case you may want to consider the 7.375" pushrods instead.
