ARP Studs?
I can shift faster than you.
The side bolts are not included with the ARP main studs. You must either purchase new GM side bolts, or apply some type of thread sealer to your existing bolts.
Jason
Jason
Chris, it's not a problem using the factory side bolts in the least. The only set of studs that comes with non-factory side bolts would be the ones that are included with the GM C5R block. Those are $$$$$$$$ studs.
Head and main studs are available through Thunder Racing
