possible coolant leak need alittle help
Old 04-13-2010, 07:24 AM
prochargedpony's Avatar
Default possible coolant leak need alittle help
I notice that I smell coolant every once in a while, seems to be coming from the passenger side, I was thinking it was the coolant overflow bottle. I have never seen a leak, my coolant light comes on every now and then but if I turn the car off then on it is gone, my coolant level is good. I had one of my techs here at work pressurize my system and NADA!!!!!! NO flipping leaks. I have checked and rechecked my lines. I also checked my radiator for oil and my oil for antifreeze, so no blown head gasket, my car never gets above 180. IS there something I am missing, or are the cooling system on the ls1's just really high pressure and my overflow just getting full and then pressure goes down and sucks it back in???
Old 04-13-2010, 08:00 AM
triche's Avatar
what about a bad sensor for the coolant level? I would replace that
Old 04-13-2010, 08:08 AM
temp isn't the problem, its the fact that I smell coolant. My temp is right on, the car has an slp thermostic switch so the fan kicks on earlier.
Old 04-13-2010, 08:09 AM
triche's Avatar
hmmmm. checked water pump?
triche's Avatar
maybe coming from weep hole????
Old 04-13-2010, 08:18 AM
Checked there. It's wierd I havn't had to add any. Its like a depressurization in the system. I am very meticulious about my cars, if there is any leak or sign of one it is fixed right away. I just can't seem to find one!!!!!!!!!!! I am just curious if I am the only one who has the problem!!! Is there any small coolant lines on them around the radiator area that I might be missing???
Old 04-13-2010, 08:22 AM
triche's Avatar
only thing I can think is to trace the line down to your radiator. maybe a hose clamp shifted or something. definately weird. good luck!
Old 04-13-2010, 08:24 AM
now that I havn't checked!!!! i am going to have my tech pressurize the system again and see if a small leak is coming from any of them.
Old 04-13-2010, 09:18 AM
Kris Mangrum's Avatar
When doing the pressure test is it holding all the pressure. Just because you don't see a leak doesn't mean there isn't one. Sometimes they can be tough to spot.
Old 04-13-2010, 09:19 AM
pressure is staying in the green, it has been on my system for over an 1hr, I am going to see if it holds for another 1hr.
Old 04-13-2010, 10:09 AM
triche's Avatar
i am willing to bet it has something to do with your hose clamps. check it out and let us know what you find. I am curious...
Old 04-13-2010, 11:30 AM
FOUND IT, there was no real leak the coolant overflow had a small hairline crack@!!!!!
Old 04-13-2010, 11:59 AM
Glad you found it.
Old 04-13-2010, 03:13 PM
ss69's Avatar
I'm betting that's what's wrong with mine. Actually I know. haha When I'm sitting in traffic, my low coolant light comes on. I can fill the overflow up and step back and watch the water come dripping out on the ground.
Old 04-13-2010, 04:10 PM
98_SS's Avatar
i had the same problem still have it really just dont have the low coolent sensor anymore i replaced my overflow tank and it still does it but never gets hot since my fans kick on at 160 due to part of my tune
Old 04-13-2010, 05:25 PM
it was such a small hole, it was the size of a pen head. I took a butane torch and closed it right up no leaks even after a pressure test. It is not any fun taking the damn thing out though. I already had the please of replacing the wiper motor!!!!!!! My arms are still battle scared from it.
Old 04-14-2010, 08:19 AM
triche's Avatar
glad you found it! it sucks when it takes a ton of time to find a small azz problem...
