Is it okay to flush oil pan with water??
My oil pan is off the car right now because of a blown headgasket, and its full of the usual peanut butter/milkshake goodness from the coolant. Is it okay to use a spray nozzle and a hose and just flush out all the gunk from the pan, let it air dry and then reinstall? I got as much of the gunk out as I could by pouring and draining it, but theres still a good amount of residue in there. Im unable to really work on the car because of an injury, so just looking to do small cleanup items while I have the time. Itll probably be months before the car is ready to run again, so I have plenty of time to let it dry. Or is that a no no to use water?
I just removed the baffle, hosed it out, and wiped up all the remaining with a clean rag, and it looks good. Thanks for the replies, though
Water doesnt do much to oil by itself. You need something that will cut/clean the oil. Like many have said carb cleaner, brake cleaner, simple green, even dish soap should work. Make sure after you use whatever to rinse it good and dry it good.
I remember taking my intake manifold off a few years ago, and found a socket inside! Im still trying to figure out how that got in there... its not like the intake can stand up on end so the opening is facing up while youre working... Unless it was sabotage! haha
