does the Manley Double Roller Timing Chain fit under the stock timing cover?
its been a while since I have done a cam swap in an ls1...
cant remember if the Manley Double roller timing chain fits under the stock cover or if I have to buy a different one
I seem to remember the SLP one fitting just fine, but that doesnt mean the manly will
just need an answer from somebody who has one and has tried it with the stock cover
Double Roller
As long as your not going to use a High Volume oil pump ( which is wider ) a double roller will fit.
The only way a Hi Vol pump will work with a double chain is grind out the inside of the cover ( in certain areas ). Also you will have to grind off part of the heads of M6 bolts on the front of the oil pump.
A Hi Vol pump was not mentioned but thought I'd let you know what my experience was with the setup in case you do have one....
Closed ex-Sponsor Account
Even with the spacers my chain touched the back side of the Melling hv pump, but took care of the with under 5 minutes with the grinder.
Put a dab of cam lube on and around any spots you think might be close, assemble and turn over by hand a few times, then pullthe cover and pump back off and check for marks front and rear
http://store.hkracingengines.com/pro...products_id=29
