ls1/ls6 block head bolts
Old 04-21-2010, 04:00 PM
Ethan[ws6]'s Avatar
Default ls1/ls6 block head bolts
I have a 2002 trans am, and I'm not sure if it came factory with an ls1 block, or ls6 block. either way, I'm going to put ls6 heads on the motor and I need to know if the head bolts were different between the two. What's the best way to tell? Or, does anyone just know off hand?
Thanks!
Old 04-21-2010, 07:11 PM
Squirts11's Avatar
SDPC sells two different head bolt kits
1997-2003 kit (10 long and 5 short) (The site says this includes Corvettes)
2004+ (all 15 bolts are short)
If this is correct, then you shouldn't have to worry either way. The first kit should work. Someone correct me if this is incorrect.
Old 04-21-2010, 07:17 PM
bww3588's Avatar
all pre 04 blocks had the different length head bolts.
all 04+ had the ones that were the same length. regardless of LS1/6/5.3/4.8...etc
Old 04-22-2010, 02:23 PM
Ethan[ws6]'s Avatar
So if my block were an ls6 I would have to get a different set of headbolts? How do I tell what block I have?
Old 04-22-2010, 05:59 PM
bww3588's Avatar
all you have to do is know what year you have. 04+ had all bolts the same length.
if your uncertian, you will find out when you pull the heads.
Old 04-22-2010, 10:47 PM
Ethan[ws6]'s Avatar
Well, I know it's not going to be an 04+. the car's an 02. I was just hoping to find out if I needed different bolts before I pull the motor so I can have everything purchased and ready go to before I ever start haha.
Old 04-23-2010, 10:01 AM
Jon@Texas-Speed's Avatar
No real way to tell by looking at it. If you pull a bolt on the outside of the block you can tell pretty quick what year it is. If the bolt is 6" it is the pre '04 (long and short) bolts and if it is about 4" then it is the post '04 (all short) bolts.
We have both sets in stock in both GM and ARP. Let us know which one you need and we'll get you fixed up!
Jon
Old 04-23-2010, 02:14 PM
Ethan[ws6]'s Avatar
Well it's the factory block and it's in an 02 so I know it's pre 04, I was just unsure if the head bolt for the ls1 and ls6 blocks were different in 2002 some people say they are diff, and some people say they are the same. I just don't know what bolts I'll need.
Old 04-23-2010, 03:31 PM
Squirts11's Avatar
/end thread/
Old 04-23-2010, 03:46 PM
joecar's Avatar
They are telling you they are the same.
Old 04-24-2010, 12:51 PM
Ethan[ws6]'s Avatar
ah.. look at me.. the easily confused dumbass haha.
Thanks for the help
Old 12-14-2010, 10:54 PM
the jester 812's Avatar
this is the determining factor ^^^^, i have a gm warranty replacement in my car, its the ls6 casting, but somehow i got an 04+ block and i always have to remember that. i ended up ordering 2 set of head-studs because i thought there was no way i could have the 04+ block. i should have checked first
Old 12-15-2010, 12:52 AM
nicenice's Avatar
it might worth u a check for sure.
Old 12-16-2010, 09:10 PM
vegaswheelsup's Avatar
Default head studs
If you have a bare ls6 block how can you tell which length too buy?
Old 12-16-2010, 11:37 PM
01ssreda4's Avatar
I have an 04 LS6 and it uses the early style.
Old 07-22-2016, 12:19 PM
Bill Cameron's Avatar
Default 02 block 04 heads
I think I know the answer but want to be sure. If I have an 02 block and 04 LS6 heads which head bolts do I use?
Old 07-22-2016, 01:38 PM
KCS
Moderator
KCS's Avatar
In case you missed it...
Old 07-20-2017, 12:44 AM
Dustin Frey's Avatar
Jon
Not to open a thread just to make a negative statement but the 04 and up had all long bolts and the pre 04 had long and short. Just want to make sure people get the right info. Thanks
Old 07-20-2017, 06:48 AM
KCS
Moderator
KCS's Avatar
Originally Posted by Dustin Frey
Not to open a thread just to make a negative statement but the 04 and up had all long bolts...
No, you're incorrect.
TSP was correct, they were all short. Not long.
Old 07-20-2017, 07:22 AM
IF you would like I could take a picture of both early and late for you, I have a set of both. Early has 4 short and 16 long not counting the little one at the top that didn't change between year. The 04 and up are all long you can look up head studs on any website and it will show you.
Quick Reply: ls1/ls6 block head bolts
