help needed ms3 or torquer 2 cam.
Old 04-25-2010, 12:38 PM
cheeseLS2's Avatar
Default help needed ms3 or torquer 2 cam.
im planning on swapping cams pretty soon and i need some reviews on both cams im debating between TSP ms3 cam or Torquer 2 cam.
my car is a full bolt on ls1 a4 with a 3200 stall
any reviews on both will be good
Old 04-25-2010, 12:45 PM
grimlock34's Avatar
I went with the tsp tsunami cam. Love it. From what ive herd it has better low end torq and carries it pretty far. 235/240 111 ls. I have an m6 though.
Old 04-25-2010, 02:01 PM
CLRD4TO's Avatar
I have a torquer v2 with stock heads. I called tsp a few times this winter when I planned the cam swap. Dynoed yesterday and it put down EXACTLY what tsp said it would do. Props to those guys, give them a call and take their word!
Old 04-25-2010, 02:14 PM
NHRAFORMULA00's Avatar
With the stall you have i would run the torquer 2. Ms3 needs big stall and or lots of gear 4.11 or both.
Old 04-25-2010, 02:36 PM
Squirts11's Avatar
Agreed. I would say the torquer 2 is the biggest you should consider running due to your stall size.
Old 04-25-2010, 03:22 PM
cheeseLS2's Avatar
how much are you putting down.? im leaning more towards torquer2
im sticking with my stock heads too.
Old 04-25-2010, 04:11 PM
SOMbitch's Avatar
I am with guys above...
ms3 will suck with your stall and gear. You could actually use a little more stall with a tv2 even. I am on a VERY close cam and I know I would have picked up on a 4k stall over my SS3600.....
Old 04-25-2010, 04:57 PM
johnster's Avatar
ms3 with that stall u got
Quick Reply: help needed ms3 or torquer 2 cam.
