Stock Lifters with Torquer 3?
I want to run a torquer v3 and plan on the install this summer. I have 135k miles on the engine and want to know if I should buy new lifters or just re-use the stock lifters. For that matter is it not advisable to use my stock lifters at that mileage regardless of the cam agressivness? I have read that the torquer 3 has fast ramps and that can lead to accelerated valvetrain wear.
Please let me know what you think and Im open to suggestions.
I don't think it's a matter of what kind of lifters you have, it's more of a mileage issue. Stock lifters work fine in most applications with most cams. It's just that most people like/recommend to change parts with high mileage. In the case of these engines, with the lifters under the heads, the lifters aren't often changed.
I cant beleive that I forget about the ls7 lifters, $100 is very cheap. The only thing is that I dont want to pull the heads yet. I was gonna go cam only then PRC ls6 stg 2.5 sometime later this year. I know I will have to swap springs so it has put me in a tough situation. Anyone selling a good set of heads.........
Thanks for the replys
Well I chose to leave the stock lifters in... wish I didn't...
https://ls1tech.com/forums/generatio...fter-pics.html
