Cam Guys, have question on this grind??
So i just pulled the cam that was in the car when i bought it.. Wasnt 100 percent sure what the specs were, so i did some calling around and found out, its a Comp Cams grind
I wanted to see what you guys would think this cam would be good for? I replaced it with TSPs 224R, in my stock long block, N/A 02 WS.6.
Heres the specs:
Comp Cam
DURATION @ .050 INTAKE 234
DURATION @ .050 EXHAUST 230
VALVE LIFT INTAKE .598
VALVE LIFT EXHAUST .591
LOBE SEPARATION 116.0
INTAKE C/L 112.0
ALL help is appreciated!
Heres the specs:
Comp Cam
INTAKE C/L 112.0
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That is just for a broad stock-like powerband. Look at the duration splits on most FI cams. People need to look at all the specs of a cam as a continuous valve event. You can't look at one aspect and assume its for a certain application. Which I am guessing that is what happened here when everyone saw the 116.
Definitely. Not decided on which heads to run though, it will probably be a little while before i get some. I actually considered having a set of 241s ported, just to keep it as stock looking as possible. Not looking for all out performance, the car already has a 4k stall, Performabuilt Level 2 60e, and 3.73s. Im also going to do some subtle weight reduction.
I would port 243s... Most people will never even notice the different casting numbers.. Unless you race for big money or something.
