TRex and PP Stage 2 5.3L Heads PTVC?
99 Camaro Z28
Stock bottom LS1
TRex v2 Cam (242/248 - .608/.612 - 110 lsa)
Patriot Stage 2 5.3L Heads
Hardeneded 7.4 pushrods
LS7 Lifters, etc etc..
Do you think I will run into any issues with the Piston to Valve clearance??
Is this easy to measure? On Heads on, etc?
Thx in advance!
Stock bottom LS1
Thx in advance!
99 Camaro Z28
Stock bottom LS1
Thx in advance!
Stock bottom LS1
Thx in advance!
LS1Tech Premium Sponsor
Last Trex we had come through here the customer ordered our stage 2.5 5.3's...we set them up for the best possible PtoV (premium cores that only need milled .003" and recessing valves slightly)....we typically lose less than .010" on the valve drop compared to stock when we do this. It was WAAAYY too tight for our comfort still! not knowing how they set their heads up......I'd flycut FOR SURE!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I am not very familiar with Flycutting... is it easy to do with the heads off? b/c they already are... the less work the better - bought these heads not realizing ill probably need it... huge fail on my part.
the heads come on and off during flycutting. in fact, each head goes on and off 8 times if done right. however, it does not have to be torqued or anything like that, just set on and tightned down with a few bolts. or....if you want to pull the pistons and rods out, you can take it to a machine shop and they can do it with a mill.
So let me get this straight, you would rather pull the engine, buy new pistons, have them assembled, possibly balance the rotating assembly, new rings, a block hone, new bearings and hardware, reinstall EVERYTHING.. rather than rent a fly cutting tool for 50-60 bucks, and spend 2 hours cutting the pistons, which can be done with the engine in the car? That sounds crazy!
You don't use pistons to increase compression.. unless you run a dome, which is stupid in an ls street engine. You gain compression by milling the heads and running a thinner gasket.
I guess I'll just take extra time doing the flycutting
I have the Lindy tool it works great...I pulled my engine to cut but others have had luck doing it in the car...just takes a hair longer...shoot me a pm when/ if you want to rent the tool...
I have intake (good for up to 2.04") and exhaust (good for up to 1.58")...
also I would not build another h/c/i lsx without flycutting the gains in running a bigger cam, higher compression out weigh the added extra couple hours by far...
if you flycut you will be able to run a thinner gasket and or mill the heads to bump the compression even more
You can measure the valve drop (how far the valve travels from its seat to the deck surface or table top) and that would give us the info needed to make that decision...but again, with the limited knowledge I have about the way they configure their heads, I'd bet against it clearing without flycutting!
__________________
