Stock ls1 lifter preload??
Old 07-24-2010, 05:32 PM
Fastdriver1992's Avatar
Default Stock ls1 lifter preload??
I'm installing a 230/236 540/540 110 cam in a 04 gro with an 03 block with stock ls6 heads. The stock ls1 pushrods r a bit long. How much can I preload the lifers. I want to be safe.
If I didn't mention anything aftermarket then it's stock
Thanks
Anthony
Old 07-25-2010, 02:17 AM
sayed_000's Avatar
i have as same as your cam numbers except am in 112+2 custom grind
running stock lifters with no problem but little noisy ..
Old 07-26-2010, 03:34 PM
Taspeed's Avatar
something like .030 is stock. any more than that and you will get nasty valvetrain noise and collapsed lifters.
Old 07-26-2010, 06:26 PM
LS1MCSS's Avatar
That's incorrect. A lot of people run close to .100. I have my preload at .085 and I don't have any valve train noise. The noise come from less preload.
Old 07-26-2010, 06:32 PM
SladeX's Avatar
Stock lifter's should be 0.060 preload as I recall. LS7 lifter's can handle a bit more.
I've never had my car so quiet out front as I did this weekend getting proper preload on my lifters. You have to strain to hear lifter noise over the exhaust note of my car now.
Old 07-26-2010, 08:00 PM
LS-1Z28's Avatar
manufacturer suggested preload is 0.05'' - 0.08''
some people go as much as 0.10'' preload. I went with 0.06'' and I haven't had any problems.
Old 07-26-2010, 08:33 PM
jerflash's Avatar
i went .080 on some ls7 lifters and its perfect
Old 07-26-2010, 11:45 PM
Taspeed's Avatar
Damn...thats what happens when you run solid lifters for so long. I stand corrected.
Old 07-27-2010, 11:49 AM
SladeX's Avatar
Pre-load varies with lifters.
Stock LS1's were 0.050 to 0.080 with 0.06 as ideal.
The LS7 lifters were a little taller in the cup allowing a bit more pre-load to be used.
Running more is not necessarily quieter. I ran 0.09~ and had terrible lifter noise on long cruises and at the end of 1/4 mile runs. I started with 0.08 as recommended by a vendor, went to 7.4 (0.09~ preload), now backed down to 7.375 now with ~0.07 preload.
Valvetrain is near silent now.
Old 08-15-2011, 01:44 AM
red 454's Avatar
how can you change the preload with a stock setup ? apart from pushrod length
are you all yousing adjustable rockers ?
Old 08-15-2011, 04:58 AM
vettenuts's Avatar
That's correct, pushrod length.
Quick Reply: Stock ls1 lifter preload??
