low oil pressure after stroker start up solved!
Old 09-29-2010, 02:05 PM
00 black ss's Avatar
Default low oil pressure after stroker start up solved!
just got off the phone with my tuner. and there is low oil pressure. its around 5-10psi at idle. i think it is either these 3 problems what do you guys think.
1) there is not enough clearance between the pickup tube and bottom of the pan
2) pinched o ring
3)bad oil pump
my oil pump is a texas speed ported ls6. it has 1000 miles on it but it was on my previous motor that was blown. still unsure of that motor problem. what do you guys think could be the problem?
Old 09-29-2010, 02:34 PM
my other question is if i have to clearance the pick up tube can i drop the oil pan with the motor still in my car
Old 09-29-2010, 02:44 PM
blsnelling's Avatar
Why would your oil pickup tube be hitting?
Old 09-29-2010, 02:52 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
With aftermarket double chain sets that use shims/spacers for the oil pump, often you have to bend the pick-up tube slightly to get it to line up into the pump properly....also you have to shim the windage tray away from the crank to clear the aftermarket crank and rods. Then you have to adjust the pick-up to pan clearance if it was altered.
OP: What were your bearing clearances?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-29-2010, 03:07 PM
since i have a 4.00 crank i had to shim my windage tray so the crank did not hit. but since i did that the pickup tube is moved further down. so would the pickup tube be to close to the bottom of the oil pan
Old 09-29-2010, 03:08 PM
my main question is can i drop the oil pan without re pulling the motor?
Old 09-29-2010, 08:46 PM
bump... really need some help here
Old 09-29-2010, 09:33 PM
SOMbitch's Avatar
Well you wiil have to drop the K-member to remove the pan..
Old 09-29-2010, 09:58 PM
1madss's Avatar
I recently installed a 402 with a TSP ported oil pump and shimmed the windage tray down with 3 washers. I did not adjust the pickup at all. I did some searching but from what I had found it sounded like I did not need to make any changes to the pickup tube. I have 50+ psi at cold idle and ~25 psi at hot idle with 10w30. It seems if I had a problem with the pickup tube I would see it at cold temps as well.
Old 09-29-2010, 10:23 PM
i put in 5w30 could that be the problem? maybe need some thicker oil
Old 09-30-2010, 02:02 PM
anybody else have any ideas? now im thinking my oil pump is bad from my old motor since shimming the windage tray down dosent effect the pickup tube
Old 09-30-2010, 02:08 PM
King Nothing's Avatar
don't take this as a dick response, but who put the engine together and where the clearances carefully checked and rechecked?
Old 09-30-2010, 02:19 PM
this local machine shop that has been around since the 70s. im pretty sure he did recheck everything im going to stop in tomorrow and find out my clearences. maybe i just need to run a thicker oil?
Old 09-30-2010, 02:48 PM
i think you might, but then again i don't know that much about building an engine. when i'm ready i'm goin to either go with a shop here locally or a guy in so cal, i hope i don't have this issue
Old 09-30-2010, 08:11 PM
first im going to try and get some 10w-30 and jack the rear of the car up and hook up a mechanical gauge and see what happends. if that dosent work im going to get a new oil pump and o ring. maybe my old motor caused the oil pump to get messed up. after that i have no idea what it could be. any of you guys have any other suggestions?
Old 09-30-2010, 08:51 PM
also would the mellings performance oil pump be a good one to use from speed inc?
Old 10-01-2010, 10:32 AM
ttt...
Old 10-01-2010, 02:25 PM
1SLwLS1's Avatar
I would put money on thicker oil. I was recommended 15-50 from my engine builder due to the clearances. I run 20-50 and at hot idle, I see around 35#. I run with the Melling 10296, 18% flow increase over the 10295, which is required if you want higher oil pressure with an engine that has larger clearances.
When I first started my 408 up, I would get down to around 20# @ hot idle with a ported LS6, but this was due to the wrong o-ring being installed.
Do you have the stock k-member or aftermarket? I have BMR's tubular turbo k member and I was able to remove the oil pan without dropping the k-member. I did have to unbolt the engine mounts and jack the engine up quite a bit.
You need to find out your clearances and then put the proper oil in with those clearances and weather conditions.
Old 10-01-2010, 08:39 PM
SSPerformance's Avatar
If u have 5psi thicker oil aint going to do ****. Find out the specs on the rods and mains.
Old 10-03-2010, 12:13 PM
1SLwLS1's Avatar
Originally Posted by SSPerformance
If u have 5psi thicker oil and going to do ****. Find out the specs on the rods and mains.
what?
Quick Reply: low oil pressure after stroker start up solved!
