Wanna upgrade from ls6 cam to Midrange cam need help....
Old 11-04-2010, 08:29 PM
Blk_Ws6's Avatar
Default Wanna upgrade from ls6 cam to Midrange cam need help....
Hey fellas wanted to say 1st off 100% to Texas-speed for my new ypipe works so fine, ok now I want to upgrade my ls6 cam to a 220 220 -565-/565-118 lsa how much rwhp over the ls6 cam will this make ?
An will it be quiet ?
Old 11-04-2010, 09:14 PM
Darkman's Avatar
My guess would be about 15rwhp gain, at most.
Old 11-04-2010, 09:30 PM
mtuggle86's Avatar
It will be quiet with the wide lsa But IMO i wouldnt go through the trouble of a cam swap for anything smaller then a 224 size cam and considering you already have a LS6 cam I would prob go even bigger then 224. Anything less and its not worth the trouble/time.
Old 11-04-2010, 09:58 PM
99Bluz28's Avatar
IMO, a tighter LSA (112-114) will give better low end power.
Old 11-04-2010, 10:43 PM
kinglt-1's Avatar
scratch the 220/220 idea and check out some eps grinds!!
https://ls1tech.com/forums/dynamomet...k-results.html
Old 11-04-2010, 11:32 PM
mtuggle86's Avatar
Screw that if you gonna buy a new cam spend the extra 25 bucks and have a custom cam specked just for your car.
Old 11-05-2010, 01:24 AM
Blk_Ws6's Avatar
good looking out , man that was a bad *** cam.
Old 11-05-2010, 10:43 AM
kinglt-1's Avatar
Thats what that cam is!!
Old 11-05-2010, 10:49 AM
kinglt-1's Avatar
no prob and yes eps is producing great results with relatively mild grinds!
Old 11-06-2010, 10:46 PM
Blk_Ws6's Avatar
so a 224 224 578 580 116 would be a killer you think ?^^^^
Old 11-07-2010, 11:02 AM
kinglt-1's Avatar
that would be a good cam, but i would still get it cut on eps "lsg" lobes.
Old 11-07-2010, 11:13 AM
Darkman's Avatar
Since the road to an EPS cam goes through Geoff Skinner, I would get his opinion at same time.
Old 11-07-2010, 01:21 PM
mtuggle86's Avatar
Maybe that one is but eps has off the self grinds also. So by just saying call eps thats not the same as telling somebody to have a custom cam spec'd so you
Old 11-07-2010, 02:12 PM
TXZ28LS1's Avatar
Dont go smaller than a 228 cam.
Old 11-07-2010, 02:21 PM
1969mach1's Avatar
i gained 42hp on my EPS custome ground cam on the stock tune.
Old 11-07-2010, 03:38 PM
kinglt-1's Avatar
go back and read my post.... I said to check out some eps grinds! You were being a dick with your "screw that" post. Thts why I responded the way I did. Grow up pal and leave the rest to pm's if you got a problem!
Old 11-07-2010, 05:36 PM
ShevrolayZ28's Avatar
You can go a little bigger on the duration. Like a 224ish. It will idle smoothly as long as there's not too much overlap. Whether or not it's quiet has more to do with the muffler...
Old 11-07-2010, 05:47 PM
Blk_Ws6's Avatar
what's your cam specs bro ?
Old 11-07-2010, 05:49 PM
Blk_Ws6's Avatar
224 is the biggest I would go an if I do it will ONLY be eps lobes I like How they turn up.
Old 11-07-2010, 05:59 PM
kinglt-1's Avatar
I like your thinking!!
