LS3 connecting rods in LS1 build - worthwhile mod?
Old 12-20-2010, 11:04 PM
andrewdruiz's Avatar
Default LS3 connecting rods in LS1 build - worthwhile mod?
Hey guys,
I've tried searching and I haven't found a definitive answer - what are everyone's opinions on putting an LS3 rod in an LS1 build?
I heard they're lighter and stronger than the stock LS1 connecting rods, and considering I'm getting forged pistons and the rotating assembly balanced, why not?
FWIW, this is going on a moderate NA application (nothing wild) that will be on the road course for about 20% of the time. I'll be pairing up the connecting rods with Katech rod bolts regardless.
Thoughts?
Old 12-21-2010, 09:27 AM
KCS
Moderator
KCS's Avatar
Originally Posted by andrewdruiz
Hey guys,
Thoughts?
I'd say they're definitely an upgrade. They are bushed for a floating pin so make sure the pistons have provisions for some way of securing those pins (ie spirolocks, c-clips, etc).
Since you're having the engine built, I wouldn't do the Katech rod bolts. You could use ARP 8740 or 2000 rod bolts and if the rods need to be resized, you could still have that done and pay about the same or less than what those Katech's cost.
Old 12-21-2010, 06:25 PM
Thank you!
The Katechs came with the engine I got, otherwise I would have gotten ARP's
Old 12-21-2010, 07:15 PM
worley.1's Avatar
What is the part # for the LS3 rod? Say for a 2010?
Old 12-25-2010, 05:19 AM
S2VYSS's Avatar
Are the LS3 rods the same length as the LS1 rods?
Is it a worth while upgrade on a standard bottom end?
Old 12-25-2010, 10:02 AM
KCS
Moderator
KCS's Avatar
Yes, they are the same length @ 6.098".
I don't think they're worth it unless you're already rebuilding the engine. In other words, I wouldn't rebuild the engine just to swap out those rods, but if I were building from scratch, I'd get them over the LS1 style.
Old 12-27-2010, 07:03 AM
S2VYSS's Avatar
So they would be a worth while upgrade with a set of forged pistons if the budget doesnt stretch to include rods?
Old 12-27-2010, 10:18 AM
KCS
Moderator
KCS's Avatar
Yes, I think so. Most forged pistons can be used with the floating pin design of the rods anyways, so that alone will save you the $50 or so to have a shop press in the pins for the LS1 rods, so they basically pay for themselves.
Old 12-27-2010, 07:38 PM
S2VYSS's Avatar
Thanks for the answer mate, I think if I go to the trouble of forged pistons I might as well do it properly and do forged rods as well
Old 03-16-2016, 12:48 AM
Luis Saldana's Avatar
My hp goals for my ls1 is around 600-650. Can the stock rods hold up to that?
Old 03-16-2016, 08:04 AM
KCS
Moderator
KCS's Avatar
I wouldn't feel to great about that with LS1 rods, but with the better floating pin LS rods, like in the later model engines, yeah 600-650whp is doable. That's assuming you have a good tuner.
Old 11-17-2020, 09:55 PM
Christian L Tolbert's Avatar
what bearings etc. would I need to do the ls3 rods in ls1?
Old 11-18-2020, 12:11 AM
Received 3,022 Likes on 2,353 Posts
They use the same bearings.
Old 11-18-2020, 07:57 PM
thank you! That what I was thinking but couldn’t find anything definitive online
Old 11-24-2020, 10:49 AM
omc8's Avatar
10 year old thread ......... keep in mind floating rod and pistons combo is going to heavier need to rebalance too .
Quick Reply: LS3 connecting rods in LS1 build - worthwhile mod?
