timings way off why? c5 zo6 after cam install 6mths ago
i got a cam install about 6 months ago left my stock timing chain.. got it done at hpe in houston .... last saturday i turnend it on and the timing was way off it was just backfiring,lagging in power and could not take it down my street so i put it back in the garage ...... could anything have damaged what could have gone wrong if it has been running perfectly ever since the install....? ive heard that it can be my crank position sensor gone bad or my timing chain got loose or its damaged ..... or something about the cam install is not correct HELP not sure what it could be i am taking it back to HPE on monday when they re open from the holidays....... i need advise from anyone thanks.....
no i dnt i have the stock crank but if the speed shop had skiped a tooth woudnt the problem have started since the install 6 months ago or the ecu would not have detected it this was this past saturday....when the problem popped up i just turnend it on and its just bad on timing...
I am not saying the timing chain was installed wrong, I am saying that it may have skipped a tooth. This can happen if the chain is worm out.
That's what I was wondering how do you know? Id take it back to them to get it checked. Did they put the LS7 chain on it? I think that's what most people are doing now isn't it? Since its designe to sustain higher RPMs or something along those lines. But as LT1Porsche said...how do you know?
I would lean towards a sensor issue and not a hard part problem. I would look into the crank position first. Those can wreak havoc on general driving.
Well here's. The update. I thought ig was timing because lack of power and backfiring and. Yes I do hav the stoc crank pulley the car was towed to. Lonestar chevy for a diagnostic and they said it was the catalic converters so I had the car towed to vetttech in katy texas. Now I replaced them wit no cats a set of lg motorsports longtubes and catless x pippe. So I went to pic up the car and and it started but it died and started back up but died again so the car stayed and its being looked at today the guy thinks it can be the crankshaft position sensor but he's not sure yet wht do u guys think???
LS1Tech Premium Sponsor
I'd agree, it sounds more like a maintanence issue than a cam install or tune problem. How many miles on the current O2 sensors? Do you run a K&N oiled filter? What'd the tuner say about the sensors' performance? Did he mention any lagging or unresponsive sensors or skewed feedback to the PCM from any sensor?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The car is a 04 zo6 and has 50 xxx k miles everything was fine when it was tuned the 1st time but thts whts being checked right now the crankshaft pos sensor. And is it hard to swap it out for a new sensor is the sensor eexpensive?
they told me the starter has to come off and also one of the longtubes has to come off and would that have made any damage my engine internals anything i have to worry about......
