What do you think caused this...
410 iron block, forged rotating assembly, 9.5 compression, 500 miles
pt88 ~14lbs of boost
~12 degrees timing
Never detected knock or heard detonation, AFR was 11.5. Fuel system was within capacity (IDC <90%). Heat range 7 NGK plugs.
thoughts? theories?
~12 degrees timing
thoughts? theories?
DENTONATION, find a new tuner. Look at the other piston, its about to toss its cookies too. Those pistons are WAY overheated. I'll guess someone tuned the knock sensors out.
more pics please.
you can definitely tell by the color of the pistons that they were over worked. what type of coolant system are you running? FMIC? what were intake temps like under WOT?
should the coolant be dexacool????? anyway can a faulty knock sensor cause this? reason i ask is cause my rear knock sensor is sending a code and i'm wondering if i can go a few weeks without replacing it or if i should replace it ASAP i only live a mile from work so i can walk if necessary
Pretty sure it melted the ring land, although there are chips on the piston and cylinder head from what looks like fragments flying around.
I will know more when I pull the engine this weekend and can get a good look at it. Cooling system is basically stock with a 34" rad. Intake temps got up to around 170 but its pulling timing down to 3 or 4 degrees at that point.
Do you think that injector could be clogged?
