ls7 lifters question
so I bought ls7 lifter from a guy and I noticed 1 was different...so I have 15 Ls7 lifters and 1 stock one..if I run it like this will it cause a problem? Or should I just go buy a whole new set?
Here's my input. A very trusted sponsor of the site said stock length is fine.I measured mine just to be safe for my cam and came up with 7.310 and went with .090 preload for my valvetrain to be quite.works just fine. And lastly GM doesn't put different pushrods in when they replace them.so if you have a stock cam you'll be fine but you could measure just to be safe
1 Post
I have LS7 lifters and bought them when I bought my heads and cam from TSP. I was told to measure lifter preload and after I ended up with a 7.40 pushrod length. It's been a while since I did my swap but I believe I ended up with .060 lifter preload.
