Finally got the motor apart :/
Old 01-16-2011, 04:50 AM
SS4Luck's Avatar
Default Finally got the motor apart :/
Knew i had a turned lifter, and THOUGHT that just the pin had slid out so that i couldnt get it out. Got everything out of the way, dropped the lifter out the bottom and found this tonight :/
Let the cleaning/rebuild process begin
Old 01-16-2011, 05:11 AM
masterz28's Avatar
Hahah, oh memories.
Old 01-17-2011, 04:15 PM
NVR_SPDS's Avatar
Nice! Did you atleast find the rest of it? I should have some pics of my dropped valve spring up soon, so your not the only one havin all the fun right now.
Old 01-18-2011, 01:30 AM
SS4Luck's Avatar
I found all of the lifter body, but have yet to find the roller lol
Old 01-18-2011, 01:56 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Im sure when you vat the block that will clear it out.
Old 01-18-2011, 03:39 AM
StormesRacing001's Avatar
that really sucks But there is no better way to start on a bigger better build
Old 01-18-2011, 07:14 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Get the block checked, you may be suprised that it survived. IF it did you could with the proper internals make a 383 on the cheap.
Old 01-19-2011, 04:40 AM
SS4Luck's Avatar
im starting to tear the bottom end out tomorrow. Well see what mysteries that is hiding lol
i would rather spend the 2K on a set of bad *** heads to go with my new trex. but the added cubes is appealing.
